Question about Pioneer PD-F505 CD Player
CD won't deliver into player, from rack.
White plastic retreival arm is off, but it doesn't look broken and I can't figure out how or where it goes back on. Any pics?
  • 1,512 Answers
They tend to break... and the cure is to replace the arm. This involves removing the transport and then splitting it, replacing the load lever, and then refitting transport. Be careful not to break the transport limit switch mounted to the chassis when removing and refitting the transport. Not an easy job for the "non handyman". Take it to a Pioneer agent if you don't feel confident. Good luck. "FixYa" rating would help my profile. Thanks
Posted on Feb 06, 2008
Sony CDP -CX200 Arm comes forward to pick up cd but goes back empty. It will not load the disc to play.
Is the second part of the arm clamping the cd? If not then the arm is probably broken and needs to be replaced.
Dec 28, 2012 | Sony CDP-CX70ES CD Player
When I turn the system on the CD Drawer keeps going in and out repeatedly by itself. When I load a CD it won't recognize it and won't play it and keeps going in and out opening and closing by...
Check all connections, such as from player to amplifier or receiver and receiver to speaker. Check and clean contacts on RCA jacks and cables and try a different input on the amplifier or receiver.
Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully.
Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function.
Have the laser-head assembly checked by a repair person if the traverse assembly seems intact and free of debris.Look for broken plastic parts, such as gears and clips,look for loose or broken internal connections.possibly have gears and belts replaced.
Jun 09, 2011 | Audio Players & Recorders
Dishwasher won,t clean dishes ontop rack
Make sure the top rack is pushed back all the way to connect with upper sprayer arm water port. Also make sure nothing is preventing either sprayer arm from rotating and there is nothing blocking the sprayer arm holes, like seeds or pieces of plastic debris. Also make sure your water heater temp is hot enough.
May 18, 2011 | Electrolux EIDW6305GS Builtin Dishwasher
Help! Same white residue and even pro can't figure it out!
It sounds like a washability problem. A couple of things to check.
See if the bottom and top spray arms are free turning. Then look closely at the holes to make sure they are not plugged with anything.
The rest of this applies if you have mode KUDG25SH, if you have a different model number on the tag inside the door let me know and ignore the rest here.
You may have a split in the upper spray arm feed tube. If you slide the upper rack out and look under it you will see the spray arm(propeller looking) under and behind there is a vinyl tube also attached to the rack, look that tube over good, if it is broken or cracked you are loosing water pressure that does the washing.
Let me know what you find and I can help more if needed
May 01, 2010 | KitchenAid 24 in. KUDG25SH Built-in...
I have a a Sony cdp cx300, 300-disc CD changer which isn't working. So I opened the unit up and found that a small white plastic arm had broken off because a CD with a loose label had grabbed it while...
is it where the lens is? that's the optical pickup. you can get a replacement through mcm electronics.
if the web site doesn't have it on there, you can call technical assistance and give them the model number and they can cross reference parts.
Dec 14, 2009 | Sony CDP-CX300 CD Player
Wurlitzer arm keeps running
check the white plastic actuator next to the gear box, it is probably broken and not actuating the microswitch underneath it, these often fail, it may look ok,, but it actually is loose and the set screw on top of it is not clamping it to the rod.
Aug 18, 2008 | Wurlitzer Jukebox 1015 One More Time...
Cdp cx300 parts schmatic
I'm having the same issue. Can you tell me where I can find the part you are talking about?
Jul 11, 2008 | Sony CDP-CX300 CD Player
Technics SL-PD9,SL-PD7A
Ouch, you should not have disconnected the front door.
Take the lid off.
take all CD's out.
Figure out where the plastic bit goes.
Good luck.
Sep 23, 2007 | Technics SL-MC6 CD Player
Number 8 flashes on display screen and disk changer is stuck
The #8 indicates either the settings for the amplifier is too high so tryi turning down both channels and/or the fuse Si3 on the amplifier panel inside the wurlitzer is blown
Aug 19, 2006 | Wurlitzer Jukebox 1015 One More Time...
Pioneer PD-F505 CD Player Logo
149 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
