Maytag A9800 Top Loading Washer
My Maytag washing machine (model# A9800 - serial# 110377) worked fine yesterday and this morning it wouldn't work at all. I checked the breaker and checked the outlet by plugging a radio into the same plug and it worked fine. I have had no problems with it before this. Any advice on what the problem might be?
  • Creativetom Jan 16, 2008
    I tried all the switches and buttons and cycles but still no response form my washer. Any other suggestions of what the problem might be? Thanks for the try
    Novelist:
  • 139 Answers
Try rotating or switching all the controls to make sure one of them is not stuck in a "wrong" possition. Try starting the washer in the different cycles...if it works in some cyles but not others, the timer has probably failed.
Posted on Jan 16, 2008
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Fuse blows on Maytag A9800 Top Loader
Usually caused by a faulty door switch assembly.
Check to see if there are TWO switches being operated by the door, the smaller of the two often fails.
Oct 24, 2017 | Maytag Washing Machines
Washer worked fine all week. Today. I went to use it and I pulled the knob out to start the machine and nothing happened. Just the little red light came on. It is a Maytag top loading model LAT9734AAE
door switch look where lid closes and depresses closed swich that swich has 2 wires on it un plugg them tape them together hit start it should work
Jan 24, 2011 | Maytag Washing Machines
My maytag neptune top loading washing machine when washing sounds like there are belts squealing and the washer tub seems to hit the sides of the machine when spinning what is going on?
This sounds like a possible Clutch issue. Is the machine model an FAV6800A or FAV9800A?
When the washer is banging around do you take unbalance errors such as dC or uC?
Do you want to DIY the fix or call in a repair service. If you could confirm your machine model number......Rich
May 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
No cold water to my Maytag Top loading washer
Pull the washer out from the wall and disconnect the water lines from the washer. Check to see if a build-up of minerals is clogging the screen on the cold water line where it enters the washing machine.
May 14, 2009 | Maytag PAV2300 Top Load Washer
Out of balance
Installed no slip carpeting underneath machine, worked fine.
Feb 15, 2009 | Maytag Legacy Series Top Load Washer
Top loading Maytag washer Model #A9700 washer fills with water then stops, no washing, no spinning
When the machine worked would the machine stop in the wash cycle when you lift the lid? If so you might check your lid switch.
Jul 16, 2008 | Maytag Washing Machines
Top loading washer sounds real bad
Before I can assist you I will need the model and serial number so I know what machine is being worked on.
Jan 14, 2008 | Maytag Legacy Top Load Washer
Washing Machines Logo
298 people viewed this question
Top Washing Machines Experts
