Question about D-Link DI-624M Router (DI624MRE)
Even with back reset hold for 10 sec. No reset at all
Even trying several time by the reset in back , my led lights still always flash and don't go off and come back, like other dlink router i had. And what is strange is the IP adress that IPCONFIG detect is 169,134.xx.xx . So impossible to goto menu . Any repair suggestions or other ideas. Thanks
email: klaud17@hotmail.com
  • zermar Mar 27, 2008
    I updated the firmware from 2.1 to 2.5 and it does not work at all. How do I re install the original firmware?
    Novelist:
  • 139 Answers
Check to make sure you're using the correct power adapter for the router. Your computer uses a 169.... address when it fails to connect to the router...this is a normal symptom when the router is not working correctly. Your router may have failed and will need to be replaced.
Posted on Jan 16, 2008
My led emerson 32 inch flat screen will not power on manually even! red light comes onand flashes 5 times then the red light just stays a solid red and the tv never powers on......nothing! tried 2 ways of...
It has gone into safe mode as an internal fault has been detected you need to take the back off to repair or replace board's up to and including the screen
Aug 15, 2017 | Emerson Televison & Video
All I get is a blue welcome screen on my Mitsu WD-65C9 DLP TV. After several seconds of blue screen, it always just shuts down. I downloaded the Mitsubishi software upgrade, but it did NOT solve...
Hi Mike,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Kind Regards,
Mjsazon
Nov 25, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
Need to reset password
if you dont remember your router password then you need to do a hardware reset by holding the reset button with a paper clip and powering the router on while holding the reset for 5-10 sec's til all the led's on the front flash a couple times
the login/pass will be
login = blank pass = password
you will need to reconfigure your router after doing this.
Mar 07, 2011 | Linksys Wireless-G WRT54G Router
I forget admin password model DSL-2640B please help i want change wireless settings .... please help me
To reset the D-Link back to the default settings, press and hold the RESET button on the back of the router and power up the router, hold the RESET button for 5 secs until the LEDs flash at the same time then release the RESET button.
The default login = admin
The default PW = blank (just press Enter)
Oct 11, 2010 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
My wrt300n power led is blinking and the rest of
Hi Friend
Please follow the steps to reset the router in a different way
1) Press the reset button for 10 secs and after that unplug the power cable from the router and wait for 10 secs
2) Plug the power cable back and press the reset button again for 10 secs and after that unplug the power cable from the router and wait for 10 secs
3) Plug the power cable back and press the power button for 10 secs again and unplug the power cable from the router for 10 secs
After trying these steps if you see the power light still blinking then you need to replace the router. Please call the customer care of linksys 1800 546 5797,they will let you know how to replace the router
warm regards
Chiranjeet Mitra
Oct 06, 2009 | Linksys WRT300N Wireless Router
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
LAN led light alway on and flashing
Reset the router:
While the router is powered on press and hold the reset button for 5-10 sec. Release the button and wait until the router boots up (1 min).
If this does not work then you can try this
Try setting it into recovery mode and loading firmware:
Unplug power cable from the router and press the reset button. While holding the reset button plug the power cable in. Continue holding the reset button untill you will see LEDs on the router flashing rapidly.
You should be able to log into the router - you will see a prompt to load firmware. The firmware is available on our WEB site: http://www.dlink.com.au/tech/
Note - suggest you d/l the firmware BEFORE you reset router
Jul 05, 2008 | D-Link DI-704P Router
Brother HL-5240 drum light flashing
Normally clearing the drum count the machine has to be on open front cover as if to change the drum press and hold the button in for about 10 second then release and shut the door. This should reset the count if not please get back to me and I'll check the service manual to see if anything in that.
Thanks J
Jan 29, 2008 | Brother HL-5240 Laser Printer
SHR 1040 "Froze Up"
You can try holding down mode and channel 2 at
the same time for 10 secs. This should reboot the recorder.
Dec 23, 2007 | Samsung 4 Channel Dvr
D-Link DI-624M Router (DI624MRE) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
