Question about Sony SDM-X95KB (Black) 19" LCD Monitor
Vertical size HI I WANT DECREASE VERTICAL SIZE ONLY FROM LCD MONITOR SAME AS CRT MONITOR.
    Master:
  • 788 Answers
LCD monitors auto adjust and use a fixed resolution. It's impossible to reduce the vertical scan. The only what I could think of is to specify a widescreen resolution if the monitor is not widescreen and this may only work if you are connected by DVI cable. Sorry!
Posted on Jan 16, 2008
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Crt monitor height are coming very small in size picture wat probelm
Did you set ur resolution screen setting higher than 1024 in ur computer panel resosulion setting?Yes than that is ur problems right there.CRT monitors modes are based on old technologies ,CRT monitors can't go up more than 1024 resolution setting.Setting resolution more than 1024 resolution for CRT models monitors will have thesse causes.The screen resolution on the screen will shrink and get smaller or will not have video resolution on the CRT monitors screens at all.Only LCD or LED monitors models can support and go higher than 1024 resolution setting has none of these causes.Time to upgrade for a new monitors technologies like LCD or LED monitors models.
Oct 17, 2012 | Computers & Internet
Hi, I am using Samsung SyncMaster 551s monitor. Suddenly i found vertical stripes in my display when i opened my pc. Pls suggest me solution. Rgds/Himel
if the stripes take 45 dgree and acolor of white then its aproblem in the line then you can decrease the brightness (the 3rd pot) and see
Mar 18, 2011 | Samsung SyncMaster 551 15" CRT Monitor
In my windows xp the software window size is different. Vertical size in left and right is different.
Hi there.
What you need to do is to adjust the vertical placement of the screen "picture". This can be done directly on your monitor/LCD screen.
The method of adjustment is depending on the type of monitor/LCD screen.
Try to press buttons on the monitor an determine how to do.
regards
Oct 17, 2010 | Microsoft Windows XP Professional SP2
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Samsung Syncmaster 551V Display is too wide
You can adjust the monitor picture size settings & position from the menu button on your monitor.
Apr 23, 2009 | SAMTRON 55V 15" CRT Monitor
Less H-width for higher resolutions
this is not the electronic problem, this monitor is made to support such (800x600) resolution.
Dec 17, 2008 | Compaq 7500 17" CRT Monitor
Monitor Curcuit Problem
re-adjust the vertical and horizontal size then exit the menu
Oct 22, 2008 | AOC LM729 17" LCD Monitor
SAMSUNG 225 UW
yes u will nee dto upgrade video card to suport that native resotion of your screen hi 1440x900 ect ok wide need better video card ok least 100 doler one
Feb 06, 2008 | Samsung 225BW LCD Monitor
Lcd monitor
Email rhartze@key-services.com with model number and your telephone number. He will call you back.
Jan 08, 2008 | Planar PC White 17.4 in. Flat Panel LCD...
Sony SDM-X95KB (Black) 19" LCD Monitor Logo
94 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
