Question about Canon DR-2580C Path-Through Scanner
Error in Shading When trying to scan
Whenever we try to scan we get this error. I have tried cutting the power for minutes at a time and it does not work.
    Problem Solver:
  • 16 Answers
The shading alignment is a software alignment fix and unplugging the unit will solve this problem. You will have to do a software shading alignment to correct your problem. I've lost my notes while moving and I can't give you the procedure for doing this.I hope this helps a little.
Posted on Nov 15, 2008
  • SquareNickel Nov 15, 2008
    Sorry, I meant to say that unplugging the unit "will not" correct this problem.You need to perform a shading alignment.
I have a windows 8 64 bit laptop. The thing is that whenever I tried to mount an iso file,it throws me the following error: PowerISO Virtual Drive is not installed correctly. Please reinstall it.(Error...
I had a Power ISO malware recently. You might want to run a scan. If it turns up clean, uninstall Power ISO and download a new one directly from their site. Or better yet, try something different. A portable app. like WINCDEmu.
Sep 19, 2017 | Computers & Internet
My Canon Pixma MP160 won't work :( It says there's paper jammed in the printer and it needs to be removed but there isn't anything there. . . HELP!!
Previously when you had tried to printing any paper the printer has adopted paper jammed error but at this time you have not turned off the system.The printer has configured paper jammed whenever you are trying to print.
It represents that it want to restart the system.
Unplug the printer and reconnect to your system.
Oct 16, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Sound keeps cutting out. Have to reboot to get back. Please help
you can try uninstalling and reinstalling the drivers,or also try to update it
Jun 14, 2010 | Bose Companion 5 Multimedia Speaker System...
I have a similar problem. I use a windows vista and print easily.
go to help from ur printer/scanner and see if they cn help u there........
if i have the same problem uninstall prigram from add/remove and reinstall printer.....mae sure before u do this to remove all cables from ur pc to printer including the power cable....insert the disc and follow the wizard instration.....hope this will solve ur problem
Jul 03, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
My car will start and then after a minute or two of running, the car will idle down and cut off but I can start it right up again and still get the same results. Whenever I put it into gear to drive it...
First scan the PCM for trouble codes using a hand held engine scanner, Then repair codes by replacing failed sensor as needed.  If no codes are present try replacing the idle air control motor.
Auto Zone will scan your car for codes for free so you know what your going to have to replace and they do have a how to do it your self instructions to what your going to replace.
Good luck and hope this helps
Apr 20, 2009 | 1997 Pontiac Grand Am
HP Photosmart C3135 is slow scanning documents
You can speed up process by choosing a low quality of scanning. Decrease the DPI ( Dot Per Inch -parameter) to 100 dpi or 200 dpi
Mar 07, 2009 | HP Photosmart C3135 All-In-One InkJet...
Huge pdf files
Try scanning a "photo" to file and using the advanced scan options to set a lower DPI. Then from the Library view you can convert that 'photo' (of a document) to PDF.
Sep 05, 2008 | Lexmark X7350 All-In-One InkJet Printer
Error 2200 for dell 962 printer
you might try going to the system restore on you computer and restore to an earlier time when your printer was functioning. it should at least reassign your drivers. I wouldn't try to update/upgrade until your printer is restored.
Mar 09, 2008 | Dell 962 Photo All-In-One InkJet Printer
LTV-27w7 blackscreen
Have you tried unplugging overnight? Sometimes mine gets screen garbage and that clears it up. Of course, now it says "Auto Scan Required" every time I power up. Maybe I should've grabbed that after Xmas 32" at Fry's for $400.
Dec 25, 2007 | Westinghouse LTV-27w7 7 in. LCD HDTV
Canon DR-2580C Path-Through Scanner Logo
224 people viewed this question
old marine
old marine
