Fault at its main digital board [System control part]. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
This is normal for the ZV457MG9 units. The Magnavox ZV457MG9 does not have an analog (NTSC) tuner; additionally there is no digital (ATSC or QAM) tuner either. It will only record on line in (L1) which is a composite input (limited to SD). The HDMI port on the recorder is an HDMI out to TV, not an input. The component video jacks are also only outputs.
Cindy Wells (If your DVD/VCR recorder had a tuner, it would record off a coaxial (antenna) cable input. Many DVRs can record off the HD connection (HDMI or component); that may be a better option for replacing this Magnavox unit.)
I found two:
The entire manual online (also has download link):
http://www.manualowl.com/m/Magnavox/ZV457MG9/Manual/191523
The downloadable version: (It SHOULD work)
http://download.m4c.magnavox.com/files/z/zv457mg9_f7/zv457mg9_f7_dfu_aen.pdf
This isn't much but it's something:
http://download.p4c.philips.com/files/z/zv457mg9_f7/zv457mg9_f7_qsg_aen.pdf
I solved it by just tapping in numbers and I came up with a code don't ask me what it is because Iwas just randomly clicking and something came up. Thanks anyway.
I have a Magnavox zv457mg9 DVD&VCR combo ,and the vcr records for a short period(10minutes) and then cuts off. This happens each time I try to record on the VCR. Any suggestions??
