Question about Philips Magnavox MS3652S 36" TV
36 magnavox tv shuts off by itself
My tv starts flashing then shuts off by itself and then i can turn it back on
  • 5 more comments
  • lmiddleton Feb 06, 2008
    My magnavox tv shuts off by itself also. The model number is 20MS2331/17.
    Can you suggest a repair and possible cost. The TV is new but I bought it at an outlet without a warranty.
  • StrikingFx Apr 21, 2008
    I also have the same problem, the situation has deteriorated now to the point that it doesn't work at all.
  • brrnugt Jul 23, 2008
    i have the same problem, i will turn it on it will flicker for about 5 seconds and then it will shut off but the green power button will still be on
  • LSCaiazza Aug 07, 2008
    our 36 inch magnavox t.v shuts off a few seconds after turning on.  we could turn it on and off about fifty times and it would stay on eventually after it would warm up.  now it has gotten worse and wont stay on at all. The green light stays on like it is still on but it isn;t.  would like to know if it is a simple fix or is this an expensive fix.  thanks
  • hotair1959 Dec 21, 2008
    Have the same problem but found out by accident that it comes on and stays on after it has gotten warm. We left our heater on in the house one day to return to a smoldering home. Not on fire but 85 degrees inside. Turned on the TV and it worked fine! Now, when I want to watch the TV, I get my blow dryer and heat up the inside and after 5 minutes or so, I can turn it on!!! That's getting really old!!!!! I want a fix for it. I call it blow starting my TV...
  • helptv24 Jan 26, 2009
    MY PHILIPS MODEL 27PS55S121 SHUTS OFF BY ITSELF . YOU USE TO BE ABLE TO TURN IT ON AND IT WOULD STAY ON BUT THEN THE TIME IT STAYED ON GOT SHORTER AND SHORTER NOW IT ONLY STAYS ON FOR ABOUT 8-10 SECONDS .THE LIGHT ON THE FRONT STAS ON STAYS ON LIKE THE TV IS ON BUT IT ISN;T.
  • Anonymous Feb 10, 2009
    mitsubishi turns on shuts off flashes red light
MAGNAVOX TV ONLY. 5-10 SECONDS AFTER TURN ON AUTO TURNS OFF-NO LIGHT STAYS ON-I AM FRUSTRATED BUT IT SEEMS LIKE THE OFF ON SWITCH JUST CLICKS BACK TO OFF-ALSO DOES SAME THING BY REMOTE
Posted on Sep 04, 2010
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
Magnavox converter box TB110MW9 shuts off repeatedly
Looks like you got a bad converter. I have the same kind and it is a pain that you can't use the remote to also control the TV. It will turn itself off after 2 hours by itself if you do not change the options, but the symptoms you describe are beyond consumer repair.
Do you still have the manual? There is a toll free number to contact them and ask for a replacement. If you do not have it I can provide it tomorrow. (I am not at home right now.) Of course you can only get one of the same converters.
Thanks for using Fixya.
Sep 02, 2009 | RCA Analog (RCA) to Digital (VGA)...
Turning off by itself
This TV probably needs the convergence amp IC's replaced. When they go bad the TV will not turn on.Call a good TV Tech and tell him you want the IC's upgraded to STK 392-150 instead of the original STK 392-120 and check all resistors in the circuit for proper value. They could be burned or open.
Jul 30, 2009 | Philips Magnavox 55P9271 55" Rear...
Turns off on its own after a few second clicks on and off for about 5 sec. until it turns itself off but the power light is still on
This is point to a fly back issue and a flyback fr this would run you $95 plus labor good luck with your TV
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | Philips Magnavox MS3652S 36" TV
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
The tv suddenly shuts off
flyback on the verge of giveing out on you.. needs a new flyback..
Apr 21, 2009 | Toshiba CF36G40 36" TV
36 tv shuts off after few minutes
have power board checked -- sounds like a short in the transformer
Dec 10, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
TV turns off by itself
you have a bad CRT causing the set to shut down. after the CRT has cooled down the computer finds all value to be ok then comes back on....
Jan 07, 2008 | Philips Magnavox 24MC4306 24" TV/VCR/DVD
Shut off and won't turn back on
try unplugging the set from the wall for 1 min and then plug it and try power button
Nov 12, 2007 | Philips Magnavox MS3652S 36" TV
Philips Magnavox MS3652S 36" TV Logo
3,061 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
