Back to:
Tags:
D-Link DP 303  Print Server
DP-303
posted by IanDalton on Jan 16, 2008
I have installed the PS Admin software for the DP-303 yet when i run the software it does not find it at all. I am running win xp Pro. i have the ip address and the mac address and i can ping it and get a reply. i am trying to set up my printers to print.
Comment by IanDalton, posted on Jan 18, 2008
I have sorted this even though i cant use PS Admin to locate the DP-303. i have managed to configure it using telnet and i can now print to all my printers.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 29, 2008
Helpful (85)
smartcard
Rank:Apprentice Apprentice
Rating: 78%, 2 votes
I too have the same problem. I even tried ARP to ARP to setup the IP address.
My PC (and the network) IP address range is 192.100.100.25 with subnet 255.255.255.0
My Print server MAC address is : 00-05-5d-5a-04-54
I want to assign the printer server IP address 192.100.100.50 and I tried the following DOS command from my XP
ARP -s 192.100.100.50 00-05-5d-5a-04-54
The command works successful, but I can not ping from my PC to Print Server.
I assume that I need to assign the subnet also? If it is then how can I assign a subnet using ARP command?
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on DP-303:
I don't want to Accept this solution
Solution #2
posted on Jan 19, 2008
Thanks for Trying (70)
kmurray
Rank:Wiz Wiz
Rating: 83%, 72 votes
Perhaps the XP firewall software is preventing PS Admin from connecting to the print server?
Rating Locked! (?) IanDalton has rated this solution as Thanks for Trying
Thank You!
Solution #3
posted on Aug 11, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
thanks, Telnet worked.. thanks for the help
Thank You!
Can you Help with these Print Servers problems?
Print Servers
examples of graphs of the fundamental functions and...
Print Servers
I've changed the cartrige and I did remove the tape before...
Print Servers
code sc990
Print Servers
We have the card. What else do we need
Print Servers
When I copy a paper the copy comes out with one third of...
Loading problems.
Repair Service
Find Print Server Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
