ArcSoft TotalMedia 3
¡Hola! ... I buyed an TV antenna for PC .... I insalled the driver and the software and when I eant to open the application I receive that message:¨TMMonitor ha detectado un problema y debe cerrarse (TMMonitor has detected a problem and it will shu down)¨ ... My PC has all the required of system, I mean Win XP, 1,7 GHz CPU, 512 MB RAM. I uninstalled that softaware and reinstalled of many times, but still doesn't work. Please, help me. My e-mail is so_what_1980@yahoo.com. What can I do ?? Thanks. ¡Hasta luego!
  • 1 more comment
  • Anonymous Jan 26, 2008
    Hi guys !
    Arcsoft TM version 3 does not start, shows me only picture and slideshow
    possibilities but no digi-tv.
    Antenna and fujtech-usb connected.
    Program-icon on desktop but has no reaction.
    Total deletion and re-installing ?
  • catjggler May 10, 2008
    I have the same problem. Installed ArcSoft TotalMedia (OS Vista). TV tuning went OK but when I try to watch I get "TMmonitor has stopped working - A problem caused the program to stop working correctly. Windows has closed the program and will notify you if a solution is available" Needless to say, it hasn't. I tried re-installing but no joy. Any suggestions - apart from taking back to the shop (that's where it will be going shortly if I can't fix it).
  • rolfbreuer Nov 17, 2008
Esponser(Zoe) 11/2/2010 1:01:34 AM
Hello Nick,
Thank you for using our products.
Regarding your issue, please try to reinstall your TotalMedia 3.5 following these steps(before that, please make sure you keep the original installer):
Step1: Pull out your device and uninstall from Control Panel -> Programs -> uninstall TM, restart PC
Step2. delete these files/folders:
W7 32-bit OS:
C:\Users\current user\AppData\Roaming\ArcSoft
C:\Users\current user\AppData\Local\ArcSoft
C:\Users\All Users\ArcSoft
C:\Program Files\ArcSoft
C:\ProgramData\ArcSoft\licensedata
W7 64-bit OS:
C:\Program Files (X86)\ArcSoft
Step3: Clean up the registration files:
1).Go to Start menu and click "Run", type "regedit" and press Enter.
2).Delete [HKEY_LOCAL_MACHINE\SOFTWARE\ArcSoft] and [HKEY_CURRENT_USER\Software\ArcSoft].
Step 4: Reinstall TM after rebooting the computer.
Hope the above can be helpful.
Thank you for your understanding and interest in our product.
Regards,
ArcSoft Support
Posted on Mar 08, 2011
Device not detected or use by other application
Go to 'Windows Task Manager' (ctrl+alt+del) and click the 'processes' tab and (if possible) stop only devices affected and retry. Be careful not to stop devices/drivers required by windows or any application in use otherwise windows/application will stop working.
If a device is not in use and still not detected or is wrongly reported, get the latest drivers and install them first. You may check device settings and make changes as required. If all else fails and you have the original software, try re-installing it after a proper uninstall.
Feb 20, 2014 | Arcsoft TotalMedia Extreme - Windows for...
Cannot detected the device or use by other application
You can get help at
https://ssl.arcsoft.com/totalmedia-extreme/how-to-use-totalmedia-extreme.html
Arcsoft totalmedia usb digital tv tuner device cannot be detected or is not supported
Did you simply plug it in, or install some drivers or what, please?
Feb 20, 2013 | Arcsoft TotalMedia
TotalMedia Extreme 2 Plug In
I used to have this problem and wanted to chuck my computer across the room,
but here is the solution. You have to unistall TME and it's drivers, and reinstall it.
Although here is the trick, when it asks you what componets you want with it,
(ex: Arcsoft media converter 2.5, Arcsoft media theater, ETC) you want to enable
to install all of them. After that wait and it should work. I did a little praying
because I was pretty desperate to record some gaming montage clips. So yeah
there you go :D
Feb 17, 2012 | Arcsoft TotalMedia Extreme - Windows for...
Arcsoft Totalmedia 3.5 installing fails to my 64bit Win7 computer. Installing stops when program asks country settings.
I have Windows 7 64-bit and couldn't install TotalMedia 3.5 It would only get as far as Select Video Device, and give 2 options: > WinFast DTV Dongle Gold BDA Filter > FM/DAB Dongle I downloaded a driver (AF9015 BDA Driver - 9.6.3.1) from http://www.unisupport.net/ Select Video Device then gave these 2 options: > AF9015 BDA Driver > FM/DAB Dongle The first one did the trick. (The second one was possibly there because I have a Kaiser Baas USB FM radio.)
Jul 27, 2011 | Arcsoft TotalMedia
Cannot remove arcsoft totalmedia from my computer (win 7 prof)
Try to boot/run your PC to safemode for to uninstall the software.
Jun 11, 2011 | Arcsoft TotalMedia Extreme - Windows for...
I can t watch TV .. i get a message that says that the device is being used by another programm ro application
freind do this
go to start
click on run
type "msconfig"
enter
click on startup tab
and disable all
restart ur pc and run ur tv program again
done
Apr 16, 2010 | Arcsoft TotalMedia Extreme - Windows for...
ArcSoft TotalMedia Theatre 3 issue
Download from Arcsoft the "BD Assistant"and it will tell you where your system is failing the HDCP check.
I had an issue with the LogMeIn mirror driver showing up as my graphics card. When I uninstalled it, my HDCP status was good again. The funny thing is LogMeIn and TMT3 run fine together but only under certain circumstances changing multiple monitors do you get this conflict.
Dec 28, 2009 | Arcsoft TotalMedia Extreme - Windows for...
Arcsoft totalmedia 3
Does anybody know where i can get the software for these dongles, as i am finding it extremely difficult to get.
Cheere
Jun 07, 2008 | Televison & Video
Computers & Internet Logo
2,637 people viewed this question
Alun Cox
David Payne
David Payne
