Bosch AquaStar 2400ES-NG  Logo
Posted on Dec 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
250 sxo out door model water got in to control unit I need new control unit do you have replacement and how much is it
Anonymous
Level 2:
  • Expert 244 Answers
  • Posted on Dec 02, 2009
Anonymous
Expert
Level 2:
Answers
244
Questions
Helped
136237
Points
811
Less than 3yrs old? contact Bosch Gas Products Technical Support: 800-642-3111.
HTH,
Mike...
Richmond gas water heater need reset code
Intellivent gas control can be reset on some units.
Honeywell does not make Intellivent.
1) Copy following links:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
http://waterheatertimer.org/How-to-replace-thermocouple.html
2) For Rheem, there is a glass vial that is broken if FV system tripped.
This requires new glass vial, which Rheem may send depending on model.
It might also require new parts such as gas control valve, and/or replacement FV sensor depending on model.
Some models require full replacement of water heater.
Each model can be different.
3) Rheem does not post service manuals, and says customers should call service technician.
Combustion parts are held in place with tamper-proof screws and combustion door gasket might need to be replaced when removed from front of unit.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Rheem water heater flashes seven times ,it is in lock out mode
You have Honeywell electronic gas control valve, and error code is 7 flashes.
Probably you have power vent model.
One manual from different company says: "Reset gas control using on-off button on front of control, replace flammable vapor sensor, replace gas control thermostat.
But with Rheem you also need specific steps: Remove gas burner and look for broken glass vial, and then blow out arrestor screen air intake using compressed air, clean burner parts, check for unobstructed venting, you will need new glass vial from Rheem depending on year and model number of water heater that appears on label on side of unit, or they may not have a repair kit for that model, and you might need a new gas control valve depending on model and how extensive problem was
You have Rheem water heater.http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
How to replace thermocouple in 42v50-50f
Copy following link:
Rheem 42V50-50 is ordinary atmospheric-vent gas water heater with mechanical (non-electronic) gas control valve, which says that unit has ordinary thermocouple, and not thermopile.
Buy generic thermocouple from local hardware.
To replace the thermocouple you need to remove entire burner assembly from water heater, and have replacement Burner access door gasket on hand. 1-800-268-6966
Combustion door held in place with tamper-proof screws
Since the water heater problem may be more complicated than just the thermocouple, and water heater flame arresor screen may need to be cleaned, and burner parts cleaned, door gasket replaced, and gas pressure checked, and piezo electrode checked, it might be best to have qualified service technician do the work for $300.
2answers
Bosch tankless watwer heater GWH 2700 ES NG - no error codes. I have low water flow on my hot water and unit will not start? reviewed trouble shooting guide, tried everything - no solution?
The unit is plugged up with mineral buildup from the water going through it... it will need to be cleaned internally....this is done by running an acid solution through it to clean out the mineral buildup...
Then it will work again...
heatman101
2 green flashes. hot water is blazing hot set at 120 degrees.have the energy smart unit model#ee2h50rd045v . what is wrong?
2 green flashes is 'High Water Temp.'
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
Typical energy smart manual:
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
3 flashes is Temperature Sensor failure.
4 flashes is Upper element
5 flashes is Lower element
Troubleshoot section says:
1) Make sure access doors and insulation are installed.
2) Check elements for resistance of 5-25 ohms (if element has a short in center of element, it might not trip breaker)
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) replace element and reset control system.
Buy ordinary 4500 Watt element from hardware store.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
4) I also suspect the self-diagnostic control box.
Manual says: Repair parts may be ordered through your plumber,
local distributor, home improvement center, or by calling
1-877-817-6750.
You need serial number, product number and model number from label on side of tank.
Gas waterheater will not stay lit
if water heater heats up and after water is hot turns off you need to replace the control unit (part where all the little pipe hook into) should have an 800 number to call where you can give serial number and model number to see if still under warranty because part is as expensive as new water heater
Burner will not increase when second faucet is turned on
Turn of the hot water valve and turn on a hot water tap in the house. If You have water flow, then you have a problem with a faucet (usually a shower valve). Go to the shower valve and see if you hear water running. If so that is likely the problem. Otherwise there is not enough gas to fire the unit that far and it will fail out. Check the manual most people install these units wrong. If you install it to code then you did it right. If you install it to the manufacturer's specs, you installed it to code and it is right. Then the only adjustment is with a Calibrated CO2 analyzer (instructions in the manual).
I have an Atwood Direct Ignition Model G6A-4E 6 Water Heater
I am a RV service tech and that is an old unit. Your control board is bad but with the age of that unit I would strongly suggest replacing the whole water heater, you can shove a pile of money at it and still have an old water heater when for 3 to 500 bucks you can have a new one with a 2 year warranty
Top Bosch Water Heaters Experts
john h
ZJ Limited
ZJ Limited
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
