Question about Rainbow E series Canister Wet/Dry Vacuum
Re: Rainbow E-series Cleaning System
Pressed start button without water present in tank. Heard a noise then it stopped. Have not been able to start again. Is it damaged or can it be restarted? Tried restart button, but doesn't work. Please help. My e- mail is velianna2001@hotmail.com
  • velianna Jan 28, 2008
    I actually found the problem : The plug fuse has gone. I Changed ot and it works! Thank god there's nothing wrong with the vaccum cleaner. Anyway, thanks for your help, I'll use your advise for future problems.
    President:
  • 1,673 Answers
Check the separator to see if it will turn freely, if not, take it off and see if the shaft will turn, if it does then the separator is causing a problem. If you can't turn the shaft, then there is a problem with the motor, and you will have to check the motor.
Posted on Jan 17, 2008
I turned the rainbow but there wasn't any water or shampoo coming out
Genuine Rainbow Aqua Mate Ii Solution Tank Manufacturer
www.sears.com/search=genuine%20rainbow%20aqua%20mate%20...
Sears"genuine rainbow aqua mate ii solution tank manufacturer" .... Hoover FloorMate Clean Water Solution Tank for all H3000 series Models, Part (59177076).
Jan 16, 2016 | Rainbow Genuine Water Tank Cap for...
What happens when i run my rainbow vacuume without water ?
The Rainbow must have water as this is the only way it filters the dirt before the motor. If you don't use water, all the dirt will go through the motor and could create serious issues. We have a cleaning service that will clean your Rainbow inside and out making it like new. Call us for details.
RainVac
www.rainvac.com
800-523-0510
Jul 19, 2012 | Rainbow E series Canister Wet/Dry Vacuum
E series Canister Wet/Dry Vacuum: My tank foamed up into the motor and now the rainb...
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 17, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Have a rainbow e-2 that was running and quit.
Thank you,
Ralph
Apr 25, 2010 | Rainbow E series Canister Wet/Dry Vacuum
My e series rainbow smells very badly... my teenager often leaves the water in for days and that nasty smell has saturated the sweeper itself. How do I get the smell out
You should always put a new hepa filter in any E and E2 series Rainbow vacuum, when it taken to a new home, or every two Years, or so, or if your Doughter makes it get funky smelling. :-) It will smell like the home that it was in, or how ever it smells, until you do.
You can also use fragrances, and deodorizer air freshener in your vacuum, which not only eliminates odors, it add fresh aromas to your air that you breath, in your home, also.
Replace the hepa filter first thing.
The water separator is the thing that spins in the center of the motor where your water basin attaches to it. It looks like a cone shaped fan looking thing. It should be cleaned after every use.
Use your Rainbow separator cleaning brush, or a tooth brush, if you do not have the Rainbow one. They are just like tooth brushes.
Never store your Rainbow canister on your water basin, with or without water in it. It can and will ruin your vacuum in dew time.
You can get manuals either here,
http://www.rainbowsystem.com/ or here,
http://www.rainvac.com
Thank you,
Ralph
Jan 05, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e2 system. Will not power up
the water basin has a safety on it so the unit cannot run without it. if you look on the bottom of the rainbow you can see a small oval shaped space that you can depress just to test and see if it still runs it will only run with this depressed.
Oct 11, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Water leaking from out of the heppa filter
Reasons for that to happen:
a) You have tilted the vac while vacuuming
b) Used the Rainbow without separator (basket like thing on the bottom of the motor)
c) Overfilled the rainbow tank with water (may have happened when shampooing with AquaMate)
Clean and install back the separator, remove HEPA, Set the Rainbow on empty water pan (with HEPA removed) turn it on for a while so everything will dry. Install new HEPA.
You will have to get a new HEPA filter (you can find them HERE)
Good Luck,
Rocky
Mar 18, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow water not spinning
All Rainbows - remove the hose and turn it on without the hose plugged in - if works better - hose is clogged
If it works bad even with the hose out:
E-series Rainbow - take HEPA filter cartridge and try then. If helps - you need new HEPA (you can get it here)
SE Rainbow vacuums - remove exhaust cap
and you may find a dirty sponge in there - just remove it and it may help.
If none of that made any difference - you may need it to be checked. If you do not mind shipping - our info is HERE
Feb 15, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Older Rainbow Noisey
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=576894
Older Rainbow Noisy
Posted by Capt_Troll on May 06, 2008
I Have an Older Rainbow (i think it's a d4)
my Old roommate ran it once without water.
it Still works now (with water), but
it's Very noisy on start up
Also I Can't seem to remove the separator (no instructions) but the nut at the end of it appears to free spin the motor when i try to turn it.
Can I Take this apart and Clean/lube it? And if so how? Or is this thing on its last legs? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow D4 is an older Rainbow Vacuum and the part where the separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. Other wise the Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit as well. Watch out… the repair of the Rainbow D4 may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Open Questions:
See all Rainbow E series Canister Wet/Dry Vacuum Questions
Rainbow E series Canister Wet/Dry Vacuum Logo
120 people viewed this question
Top Rainbow Vacuums Experts
Doris Wittkamm
Level 1 Expert
Jim Parker
Jim Parker
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
