Question about Logitech X-230 Computer Speakers
X-230 Speakers Hum
My Logitech X-230 speakers have started humming and the bass sounds are extremely distorted. No problems until about 2 months after I bought them. Any clues the humming is driving me crazy!
  • 1,067 Answers
Bad brain in it or u can try to see if its pused in all way cables in back dl latest sound card drivers
Posted on Jan 16, 2008
Can I use my Logitech x-230 speakers without the sub-woofer? My sub-woofer got busted!! Any suggestions?Perfectly good speakers!
i had the same problem with same speaker system. the amp for this system is inside the bass speaker. if your amp is still working but your bass speaker is not you could cut the wires to that speaker making sure the cut wires do not short out. i was quoted more to repair them than it was to buy a new set. but i wont be buying logitech again as ive had two lots fail.
Jan 18, 2012 | Logitech X-230 Computer Speakers
Hello. I just purchased these speakers and there is a low static hum in them. Also, if I turn up the bass volume on the subwoofer I get a deep hum and no sound. Any assistance would be greatly...
Double check your wiring again, sounds like something is either not hooked up right or maybe you got faulty speakers. There shouldn't be any hissing or humming in any speakers. Get a flash light and make sure you have it in the right spot on your computer most sound cards have about 5 different jacks you could have simply put it in the wrong jack.
May 15, 2011 | Cyber Acoustics CA-3080 Computer Speakers
No sound
Hello endow1, hi, try this test, unplug you Logitech audio in plug and touch the input, you should hear a humming sound, Adjust the volume settings to high to hear it. If you cannot hear the humming sound, then there are problems you need to check. Place you speakers near your ear and adjust the volume Up and Down, you may hear a soft hum that should go up and down. Absence of the hum means that the speaker has loose connection from amplifier to speaker driver, or loss of power, check to see if there is pilot light.
Aug 19, 2010 | Logitech X-140 Speaker
Re: Boston digital BA735. Hum with or without input signal.
Hmmm I just got the same problem. They worked fine on my old Dell desktop but when I plugged them in to my son's old Dell PC (maybe 1 year newer than my old one) they all hum like crazy - as you say even if it's just the power plugged in and nothing else. Yes it does have the original power supply. I get no music (but still it hums) from digital out/in but when I switch to analog out/in I hear the music and it still hums, plus the sound is distorted. Wierd.
Jul 14, 2010 | Boston Acoustics BA735 Computer Speakers
Constant hum from speakers
It sounds like you might have a grounding issue. Try connecting to the wall outlet with a ground prong lifting adapter. Not just the speakers but the source plugged into the speakers also. Good luck.
Oct 09, 2009 | Logitech Z-10 Computer Speakers
Hum in TEAC EX-M3 radio
(1) Is the hum out of both speakers?? (2) Is the sound distorted out of any of the speakers?? If the answer is yes to 1 and no to 2 then it sounds like one of the smoothing blocks or capacitors have gone down and requires replacement. If no to 1 then you probably have blown the output chip or taken one side of it out, check all connections to the speakers, try not to use tape joints which are unreliable. If you do have to piece the cable, solder the connections. Then replace the chip, Ian
Aug 13, 2009 | Teac EX-M3 CD Shelf System
Loud hum when Bose Companion 3 Series II speakers are turned on.
I had the same problem for many months. I asked a sound & video professional and he suggested I move the subwoofer away from any power source. I had the subwoofer next to my UPS. Once separated and moved all wiring away from the power supply (about 12") the low bass hum was practically gone.
Jun 28, 2009 | Bose Companion 3 Series II Multimedia...
Extremely loud hum/buzzing from speakers
any kind of speaker that fits the plug support at the back.....and if dont work just reply...
Apr 04, 2009 | Logitech X-230 Computer Speakers
Logitech X-540 5.1 speakers loudly crackle when volume moved up or down
mine does that, its complety ok. Just run them at highish volume for about 30 secs should fix them, its just static.
Feb 12, 2008 | Logitech Z-540 Speaker
Distorted audio
I think the volume increasing or decreasing of you woffer box has been got damaged please change your button as quickly as possible...
Thank you..
Jan 02, 2008 | M-Audio DX4 Active Studio Monitors (Pair)...
Logitech X-230 Computer Speakers Logo
492 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
