Question about Kenmore 24 in. 16309 Built-in Dishwasher
Repairman out twice...quote too high -replaced plug in parts Sears guy said were needed in control board area. Still-blinking lights /no water filling/no progress thru sequence. Sequence shown on "
\\\\\\\\\\\\\\\\\\Dishwasher is just a few months out of warrentee. Used only 2 to 3 times a week till it quit. Worked perfectly and I loved it before. I'm in 3rd floor condo...seemed to happen after work was done on piping at building
where water is heated across the way. Don't notice any pressure difference
anywhere else in condo. Can you help? $150 on parts so far and much
frustration. Much Mahalo if you can (Hawaiian thanks) Jcrainbows in Makaha
Hawaii on Oahu island.
  • jcrainbows Jan 16, 2008
    Used paypal to sign up-notice the email address is old. Correct
    address is jcrainbows@hotmail.com. Mahalo again. J
  • jcrainbows Feb 05, 2008
    Havent been able to get ahold of an olm meter to test the
    water inlet solinoid-any ideas without paying a full charge of
    repairman? part is quoted at only aprox $25 and is in stock.
    Genius:
  • 1,003 Answers
REPLACE WATER INLET SOLENOID
Posted on Jan 18, 2008
Moisture on control board
Yes, that's a problem. You will probably need to call out a Sears dishwasher repairman to replace the control console, and to figure out how the water is getting into the control console (usually through a bad seal in or around the vent).
Mar 13, 2015 | Kenmore Dishwashers
TV has been working great for the past 6 years, this morning when turning on the TV nothing happens except the standby light flashes about 9 times on and off. No click like I usually hear when turning on...
Hi Dave,
We have had this same problem twice now - the first time under warranty (no problem) and now currently. The 9-blink error code refers to needing to replace two diodes on the G board. Specifically, D6301 and D6116.
The warranty time, the repair guy came and resoldered the new diodes onto the G Board, reinstalled the board, and was on his way. We had no problems for the next 3 years.
THIS time I ordered the two diodes from Andrews Electronics (www.andrewselectronics.com) am removing the G board myself and taking JUST THE BOARD to a local TV repair guy. This is a LOT cheaper than calling Sears or taking the whole TV to the repair guy. Here are the links to the specific diodes:
D6301 - http://parts.andrewselectronics.com/search/electronic-parts/parts/7/6-500-567-21.aspx
D6116 - http://parts.andrewselectronics.com/search/electronic-parts/parts/7/8-719-081-97.aspx
They are a heck of a lot less expensive than other places and the customer service I received was great!
I hope this helps!!
Jan 12, 2011 | Sony KP-57WS520 57" Rear Projection...
Microwave has an error code F9 after running for about 5 seconds
Some quotes from other forums, but note that you need to look up your model to verify part numbers:
"F-9 on this microwave IS inverter related. There is a service tech troubleshooting document stuffed in behind the control board cover which has some testing proceedures. My problem was the magnatron and checked out bad with the help of this document. It would run for a few seconds making clicks and then say F-9. It has been working great since I replaced the magnatron PN 6324w1a002c."
"f9 model 721.63764300
Kenmore Elite 36 " over tne counter microwave is supplied by LG made by Gold Star, made in China. It's main problem is the high voltage inverter board supplyed by Sears Parts. If you get a F-9 code on your microwave display screen and the micro quits it's probably this board. Reset the machine by pulling the power plug and waiting an hour. If it is the high voltage board is at fault it will probably fail after 45 seconds of start up. This part is really hard to get at but is less than $100. A qualified technician should be able to remove and repair this item in less than hour. Some techs will quote you $300 labor, don't buy it, it should cost a $100 or less. No need to buy another microwave."
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, & testing.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########.
BUT once you have the part number from the Sears site, you can often get the parts cheaper
here.
May 25, 2010 | Kenmore Microwave Ovens
Ice maker not working properly & Ice cycles in freezer
THIS IS WHY PEOPLE USE THIS SITE.ORDINARY PEOPLE NEED FRIENDS TO HELPOUT....
find an elderly person in your area that needs help, not charity.the feeling is priceless...
Feb 11, 2010 | Freezers
I have replaced the Power Supply Board, and Both of the Main Boards. At first it would not power up, and the LED would burn constantly. The SEARS repairman replaced the Power supply and the board next to...
I recheched the A board, and at the spot where the three projectors plug in I unplugged them and reseated the plugs. When I powers the set back up it all works fine. Thank you, but I no longer need assistance. I will contact you in the future if I need assistance again.
Dec 10, 2009 | Sony KP-51WS510 51" Rear Projection...
Th42px80u- tv wont come on and red light flashes 10 times
Here are all the Panasonic blink codes.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Oct 21, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Sony kv-32fs10 won't turn on...stand by light blinks continuously
No,ur power ic board converter is dead.
U need a new one.U know some Electronics repairs,open it take off the board where near the A/C cord plug in is use the parts numbers buy it from the Web.replace it that might work, if only the power prob.nothing else.
Aug 19, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
May 08, 2009 | Dishwashers
The flashing light blinks 7 times on the clean indicator area , but the dishwasher will not function and when you press cancel it starts running but nothing washes through any cycle at all. please help
ok well usually it is not sensing a temperature change in the water or not getting hot enough. so you can reset the dishwasher and try running the hot water in the sink before starting the dishwasher. if it fails again there is a heating element and control board kit that would need to be installed. you can reset the dishwasher by pushing "high temp wash" and "heated dry" back and forth until all the lights light up then you can hit the cancel and drain button twice.. put detergent in and run it.
Mar 04, 2009 | KitchenAid Dishwashers
Kenmore 24 in. 16309 Built-in Dishwasher Logo
169 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
