Welds then stops, welds then stops.
Usually this is caused by a bad liner in the mig gun hose, or worn out guide rolls in the drive unit, or if this is not the case the speed of the wire might be set to high as this would force the wire into the weld causing the motor to heat up from resistance and shut it down on safty. Hope This Helps Don
welder has a squealing sound when on down hill pipe mode does not matter what size electrode or welding position
