Question about Dell 1700n Laser Printer
Dell 1700 laser printer has Low toner and error lights flashing
Both the Error light and the toner low light are flashing in sync with each other. Please advise on the error and how to correct.
  • 4 more comments
  • Anonymous Apr 03, 2008
    HI !
    I'm Henry , I have been read your recomence about Dell printer problem ; my Dell printer It has the same problem , show me fix please .thank .
    My address ; phuongdinh9999@yahoo.com
  • tgrant251 Aug 21, 2008
    All lights are flashing and will not stop.
    I have already tried opening the front and holding down the cancel button.
  • coikg Sep 17, 2008
  • Public figa Oct 11, 2008
    I shows the toner low and lighting error
  • Public figa May 11, 2010
    Help me
  • Anonymous Mar 25, 2014
    How to shut off this light?
I was able to reset the drum counter using your instructions and print a test page with the 'Continue' button, so I know that the printer is functioning but my system still tells me that I have an "Unknown Toner Level" when I try to print a document and will not print. Is there a fix for this?
Posted on Oct 22, 2008
Ya!!! It was very hepfull. Thanks a lot.
Posted on May 15, 2008
Reset the photoconductor (PC) drum counter on the Dell™ 1700(n) printer.
To reset the photoconductor (PC) drum counter, perform the following steps:
1. Turn off the power using the switch on the back of the printer.
2. Open the front door of the printer.
3. Hold the Continue button down, power on the printer, continue to hold down the Continue button until just the Error LED is on solid, then release the Continue button.
4. Close the front door.
The
Continue button, Ready/Data, Toner Low, and Load Paper LEDs should all be lit.
5. Wait for the printer to complete its POST process.
This is completed once the printer begins emitting a fan noise and the rollers start, then stop.
6. Press the Cancel button four times slowly until the Toner Low LED is lit.
Dell 1700 laser printer has Low toner and error li - clip_image001.gif NOTE: This is the option for resetting the drum counter.
7.
8. Press and hold the Continue button until the LEDs all begin to rapidly cycle up / down in sequence, then release the Continue button.
The Toner Low
LED is the only one on.
9. Cycle the power on the printer.
10. When the printer is ready, press the Continue button once to print a settings page.
11. Under the heading Cartridge Information, verify the Photoconductor value is 0K (zero-K).
Posted on Apr 09, 2008
Leave the printer on. Open the front and hold down the cancel button until all the lights are flashing in sequence. Close the front while still holding the cancel with the lights flashing and then release the cancel button. This should reset it.
Posted on Jun 06, 2008
  • icemanjulian
    icemanjulian May 24, 2012
    Thank you Guest. I follow your easy instruction and it work. Saved 85 dollar and a piece of junk for the landfill.
Toss it out. That printer is a piece of junk. I have 4 fairly new 1700's and they all just about crapped out.
Posted on Jan 28, 2008
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Dell 1700 laser printer has Low toner and error lights flashing
Try removing the toner cartridge and putting it back in place.
Try also unplugging power cord for ten minutes, and check if this clears error message.
Inspect the printer for foreign objects, or paper stuck inside.
If this does not work, it is a faulty drum.
Posted on Nov 07, 2008
Bappa170873
  • 505 Answers
Thanks
Toner low and error is flashing
Your PC has detect low toner in your printer that led it show error flashing. Normally It can cause by 2 things : 1. You have a low toner ( need to replace toner) 2. You have a clogged up toner ( need to clean /service the printer)
Dec 03, 2010 | Dell 1700n Laser Printer
Flashing error and toner on Dell 1700 and will not print even after replacing drum and toner this happened before and I found on line sequence of pushing the buttons on printer to clear...but i can no
After replacing fysicalythe photoconductor/imagaging drum, leave the door open. Press and hold Cancel untl all lights flash in sequence to reset the printer. Close front cover.
May 28, 2009 | Dell 1700 Laser Printer
Dell 1720dn toner error
You have to reset the drum count on the printer after you replace the drum. Call dell tech support they will not charge you for help resetting the drum even if you are not in warrenty.
Nov 16, 2008 | Dell 1710n Laser Printer
Thanks
Nov 07, 2008 | Dell 1700n Laser Printer
DELL Laser printer 1700/1700n
All flashing lights for the Dell 1700 series (1700, 1710, 1720 including those that have n or dn as part of the model) printers is a service related error. When double pressing the continue button twice quickly, the printer will give a secondary error code, narrowing down the printer part being effected. It is possible to even narrow the error code down even futher by double pressing the continue button and taking note of which combination of lights come on, wether they are steady or blinking. Most generally when this series of printers, when you get all flashing lights, something major is going on with the printer. It could be pointing to the fuser, or main board, etc. You can call dell warranty support and they will help narrow down which part is being effected. Most generally, what is being effected is not cost effective to get fixed if you are no longer under warranty.
Sep 18, 2008 | Dell 1700n Laser Printer
Dell 1720dn Error and Toner light on
After replacing the drum unit you have to tell the printer that you've done it(it's not smart enough to figure it out itself). Have the front door open and press and hold the Cancel button on the printer until all lights flash in sequence then let go. Then close door and try.
Apr 09, 2008 | Dell 1720dn Laser Printer
1700 Drum Error
hold cancel button down with door open, this should rest it
Mar 27, 2008 | Dell 1700n Laser Printer
Dell printer 1700
First unplug power cord and plug back after 10 mins.
If problem persists, then it is probably a toner error, if the toner is nearly finished. In this case you will see the led flashing only when is printing. Sooner or later the printer will start printing blank or faded pages and you will need to change toner
When is not toner, with same symptoms as above, it can be drum error, in this case printer will keep printing but shows flashing light, at a certain point you will need to change drum kit.
If light flashes and printer does not print, then it is either paper jam inside, or one of errors above at final stage, or one of the door not well closed (check them all), or printer faulty (fuser, heads mechanics etc.), in this last case call service.
Mar 21, 2008 | Dell 1700n Laser Printer
Error light on and toner low/ replace drum light on
I was talking to dell and they said it was because of my toner. Guess I will try a new dell toner.
Feb 21, 2008 | Dell 1710 Laser Printer
Dell 1700n Laser Printer Logo
7,860 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
