Question about AOpen MX46-533V (91.89U10.061) Motherboard
MX46-533V Motherboard Problem
Cpu fan wprks but nothing else
  • Anonymous Jan 24, 2008
    iv tried swping power supple no change when i connect a dvd drive or hardrive they wont work until i unplug the data cable then hardrive starts sping and drive will open but when i connect data cable back on light coms on dvd drive but thats it tried processor in different machine and works well so can any1 help as its proberly sumthing really simple but cant think wot as i dont have any drivers for it would that stop it from booting to sceen or not
Try swithing the power suply or battery
Posted on Jan 16, 2008
6ya staff
SOURCE:
Sys fan nor cpu fan working and black screen
Try a known , good working PS. If that does not do it, you have serious mo bo issues.
Mar 27, 2017 | ASUS PTGD1-LA Motherboard
It was just this morning when I tried to turn my pc on.. unfortunately it did not. ! when i press the power button on cpu it turns on for a few second like one or two but immediately after it drops the...
Try replacing the power supply - I had a similar problem that was fixed that way. If that doesn't work, it's probably the motherboard itself. The CPU is also possible - have you overclocked it or otherwise cooked it? Is the CPU cooler/fan blocked with fluff, or has the fan been slow (or stopped) - noisy fan is a sign of bearing stiffness/partial seizure which slows the fan and lets the CPU get too hot. If the CPU is fried, you get the symptoms you describe (MB won't start the PS)
Dec 23, 2010 | ASUS M2N-MX Motherboard
We were given a Gateway EL500S computer to use for our kids. We set everything up. We did try to install an ethernet card. When we turned it on, nothing happened. The light comes on the ''on'' button but...
when you say no fan you mean the cpu fan or the case fan. the cpu fan is on top the cpu. make sure that at least this starts. if it does not start then shut down your pc immediately as it can burn the cpu.
it could be lots of reasons, but make sure that you have connected the power supply cables correctly to the motherboard. probably the motherboard may have a small led. check if that lights up. it means that power gets to the motherboard.
i would advice to find someone that has more knowledge.
Jan 24, 2010 | Computers & Internet
Bios not starting
Gitu, remove tha fan, the cpu and the RAM. RE fix them in their respective places. Switch the machine on It shud work. Check the battery on the motherboard. May be it is dead. How old in your machine? Replace the button cell on the motherboard.
Aug 05, 2009 | Intel SuperMicro SUPER Motherboard - 810...
USB PORT NOT FUNCTIONING
does your machine make it to the windows login screen, or does it fail before.
I think you haven't installed you CPU correctly, or maybe did not put heat sink compund evenly on the heat sink, and that causes the CPU to overheat and freeze.
Mar 23, 2009 | Mercury P4VM800M7 Motherboard
Replaced motherboard & pc won't power up
Yours memory card(Ram) may not suitable to your motherboard, read the instruction manual of motherboard, what ram is suitable for your motherboard.
Mar 17, 2009 | ASUS M2N-MX Motherboard
System will not start up. Cpu fan spins once, then nothing.
It is more than likely that when your old power supply died a death, it damaged some components on the motherboard. Replace the Motherboard and chip, and you should be back in business. You can pick up some good value bundles to save money on buying the parts seperately. The power supply working again after turning off and on, is because there is a little trip in the power supply that triggers when it detects a fault. Powering down resets that trip allowing it to try and work again.
Mar 05, 2009 | MSI K7N2 DELTA2-FSR NVIDIA nFORCE2 ULTRA...
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Mach speed motherboard problem
I had the same problem once. I took it to CompUSA to have them diagnose the problem, and they said I fried the motherboard or CPU. The fans turn on just because your power supply is on.
Jan 14, 2007 | Mach Speed P4M800 (890552603480)...
AOpen MX46-533V (91.89U10.061) Motherboard Logo
54 people viewed this question
Top AOpen Computers & Internet Experts
Ekse
Gustavo Ortiz
Gustavo Ortiz
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
