Question about Panasonic Lumix DMC-FX12 Digital Camera
Built flash stop working
After taking a few shots the built-in flash stop working
  • Anonymous Feb 05, 2008
    auto flash will not work. I have selected "force flash mode" and it still won't flash..
    Thanks!
    Genius:
  • 2,985 Answers
Check the manual to ensure you are doing all that has to be done.
If it still fails. and is under warranty return to the seller.
If out of warranty contact manufacturers support line
Posted on Jan 16, 2008
Bower sfd728
What was the shutter, aperture, and iso set at? How are you triggering the flash? (wireless, wired) Sounds like the images are just getting blown out. If you throw them into a photoeditor, and if the files are in RAW format, does taking the exposure down reveal more details?
If you need further help, reach me via phone at https://www.6ya.com/expert/jordan_b2a1f9d717fb9470
May 31, 2013 | Cameras
Error code when using the built in flash
try to remove first the battery for an hour., to reset all the save setting's.
Let me know here again.,,
micro
Jul 29, 2008 | Sony Alpha DSLR-A100 Digital Camera
Can the camera sp-800UZ take rapid shots pics with flash going off every pic taken
In short, no. As with all flashes, the capacitor takes a while to recharge (via power from the low voltage battery which is amplified to many thousands of volts in the capacitor) between each shot. How long exactly depends upon how far it's discharged each time, so for close-up objects which fill the frame and need little flash, the discharge will be relatively low and you may get a few shots off in a row, and for distant objects using a more powerful flash discharge it may totally discharge with each shot.
The bigger and more powerful the flash unit, the better it will perform in that respect which is why professional external flashguns are big, bulky and cost hundreds or even thousands of dollars. A built-in flash such as on your camera is a compromise solution and is not intended for heavy use. More advanced cameras may have their own built in pop up flashes to take close up snapshots, but for anything else have connectors to enable the use of more powerful external units.
Mar 04, 2011 | Olympus SP800UZ Digital Camera
Nikon d40 built in flash not firing but it popped up
there is a sensor in there that tells the camera the flash is up you need to take it to a repair shop its not a at home thing
Mar 11, 2009 | Nikon D40x Digital Camera
D80 won't take pictures sometimes unless I turn it off and on
It may be that you are shooting in a light level that is too low (indicator light) try upping the ISO and are you using the built-in flash or a separate flash?
Nov 25, 2008 | Nikon D80 Digital Camera with 18-135mm...
Sb600 wireless mode not working...
Remember that even though sb-600 is wireless, it is based on infrared. This usually means having a clear line-of-sight between flash commander and remote flash. Any object that gets in way can block signal from flash commander. Weak batteries in flash will also cause remote operation to be sporadic.
Mar 13, 2008 | Nikon Speedlight SB-600 TTL Flash
D40X flash problems
As the manual warns, never operate the camera (or any device, in general) if you notice something like that. Remove the battery, and send your camera for service
One can only guess what was the source of the problem. Did you drop the camera, expose it to high temperatures (e.g. left it inside a car in 40 degrees Celsius) or expose it to torrential rain?
In any case, how long it will take to repair it (or, more likely, replace it) depends on your local Nikon service department.
Dec 08, 2007 | Nikon D40x Digital Camera
Canon 20d flash
push the flash into its resting place with a little pressure, turn unit over, take an image requiring flash while pushing on the flash and then quickly release the flash.
something is likely broken and may clear out when camera in alternate position.
otherwise, off to service. don't force it.
good luck
mark
Dec 01, 2007 | Canon EOS 20Da Digital Camera
Nikon D40X inbuilt flash
If it's withing 30 days, get it exchanged. I have a D70s and it's been working fine for me, maybe something with the D40x with other customers? Take it back to the store and let an "instructor" try it out to make sure it's not a setting.
It's great for the manufacturer to know about any problems so they can get a good sample of problems to help many people. Good luck.
Nov 16, 2007 | Nikon D40x Digital Camera
Panasonic Lumix DMC-FX12 Digital Camera Logo
83 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
