Question about Alpine CDA-7998 CD Player
Alpine cda-7998 i have 1 .the problem is the brackets for the face 2 go hide in to the radio,i think they are bent.cause the face wont go back in the radio...can u help me find the brackets they are the motorized ones tha hides the face. i look everywhere. i cant find them. what are they called.i already fixed a chip that was bad.can you help me please
  • hizzo Jan 16, 2008
    i did that but they dont give a pneumatic of the face
  • Anonymous Apr 26, 2008
    wat is the brackets that make the face go into the radio called.or can i send it out?
  • 111 Answers
Go to pacparts.com
THE ARE ALPINE AUTHORIZE PARTS DISTRIBUTORS
I recommend you to get the service manual first to look the mech explored view and see exactly the parts you need,also you may need the information for Assembly the mech.
Posted on Jan 16, 2008
Install foot rest
If you have the swing on footrests or legrests for a Pride Jazzy series with 2-pins on the hanger brackets please be sure that the hanger brackets are properly installed on the chair with the pin side of the bracket facing to the outside - not inside. To put the footrests on - align the lower pin first with the footrest at a 45 degree angle to the outside of the chair. Then align up the top pin and lower the footrest onto the hanger bracket. Rotate the footrest towards the front and lock the cam lock in place. If the cam lock has a handle that is bent it will interfere with the lock and need to be replaced or bent back in place.
Nov 13, 2013 | Pride Jazzy 1113 Power Chair
Time set
Hello
Try to download its user manual from any one among the folloing links. It will have all details.
http://www.pdfjungle.com/alpine-owners-manual-cda-7998-for-alpine-cda-7998-cd-player/alpine-owners-manual-cda-7998-for-alpine-cda-7998-cd-player-pdf-preview/
http://www.dataentryjobs.us/67948.html
http://www.retrevo.com/support/Alpine-CDA-7998-Car-Receivers-manual/id/23223dj397/t/2/
If you feel any difficulty in downloading the manual, inform me by Fixya comment, along with your email address. I'll send a copy of the manual to your device by return mail.
Mar 10, 2012 | Alpine CDA-7998 CD Player
This dishwasher,was installed without being secured,so it slides in and out,with little or no effort. The instructions say to install screws in the top and bottom, or buy side mounts. My question is : How...
Need more info ! hard to answer w/o a photo or even knowing you cabnet or countertop material . If you have a bit of a recess,or can create one, you may be able to go to most any home improvement store and buy common corner or "L" shaped small metal brackets. Very common and in many sizes,Pre-drilled/holes or holes already in them, very inexpensive.
The gasket around the machine door that keeps the water in cannot be compromised by having anything across any part of it`s surface when door is open or closed. The door will hide the brackets when closed if placed properly. The trick is determining how much surface area you have to work with around the gasket/door seal , to the cabinet sides or countertop bottom .This distance determines what size "L" brackets to use.
Slide the machine to where you want it , if it goes to deep into /under the counter or towards the back wall, put pressure treated scrap lumber behind the machine legs on the floor till it`s out to where you like it and the door opens and closes easily. (proper recess) If the cabnets on each side are wood , measure from the gasket to the side of the cabnet.
Is it a tight fit or a little space between the cabnet sides and machine face behind door area? Buy "L" brackets that will screw to the cabnets , cover the gap, but wont touch the door gasket .while resting tightly on the machine face behind door area. The brakets can alway`s be trimmed with a hacksaw or cut off wheel . Get flat head self tapping screws to mount the brackets to the wood cabnet sides. If possible, you may be able to mount to the outside front of the machine, behind the machine door, but outside the door gasket area/ diameter as well . It would give you extra strength but not 100% needed.
You may need to drill small "starter" holes smaller than the self tap thread diameter that are on the screws you puchased , to start the screws in the wood , metal , plastic , ect. Before you drill or mount , do a bracket placement trial run by using tape to hold them where you think they fit/work best . Again make sure the door opens, closes and hides the brackets . The higher up from the floor (closest to the countertop) the brackets are used , the more secure the machine will be ! It won`t flop on it`s face when you open the door to load it or put weight on the opened door.
You can also bring a printed copy of this to your choice of local home improvement store. Matching brackets to the right screws , ect , ect, is easier for them If they understand what you are doing and you find the right employee.
Hope it helped you ! Good Luck !
Jul 06, 2011 | Frigidaire FDB520RH Builtin Dishwasher
It wont bring the bobbin thread up, then after several trys and i get the thread up it wont sew
Generally, this is because the needle is inserted wrong or because it's bent. In the first case, the top of the needle (called the shank) has a flat side-this has to be inserted so it faces the back or away from you.
In the second case, when a bent needle stops the top thread from picking up the bobbin thread. Even if you think your needle is fine, change it to see if this solves the problem.
May 11, 2011 | Bernina Virtuosa 150
How do i get inner glass door off ignis akl905 to clean it
Simple . for the ignis AKL 950 OVEN. Takes two minutes.
1/ get a 7mm socket or spanner.
2/ open door flat, no need to take off.
3/ bottom of glass, both left and right are two black plastic brackets , with a 7mm bolt through them. Undo bolt both sides.
4/ remove plastic bracket, just lift out.
5/remove door , clean.
Put back on, refit brackets and tighten bolts.
Job done.
Takes two minutes. Just remember which side of glass faces inside. think both sides same, but could be wrong.
Hope this helps. sid . derby..
Feb 14, 2011 | Whirlpool Ovens
I'd like to fix my radio...how to take out the radio so I can repair it...thanks
Lets see if I can help you I have done this it's been a long time ago it was on a old model. I think there is bracket on the back of the radio that holds it in and serves as a ground take it off. Then you have to take the face plate cover off of dash be careful keep up with the screw clips.
Nov 05, 2010 | 1992 Oldsmobile Ninety Eight Regency
I have a Alpine CDA 7892 CD head unit I just installed and the radio works perfect but when I play a cd it sounds very muffled and I can hear bass only. Is the unit bad?
If the sound is coming out clearly with the radio on, then there is a problem with the cd drive or its connections. If your stereo has aux. inputs, you could run an mp3 player until your ready to replace it.
If you need further help, reach me via phone at https://www.6ya.com/expert/david_f2436a37cbb50365
Apr 12, 2010 | Alpine CDA-7998 CD Player
I own a GE WBSR3140 Washer and I'm getting a banging sound whenever the machine is a wash or rinse cycle but not on spin. How do I get at the problem ? Remove panel from the front or the top?
First of all, you do remove the a panel from the front.
On the inside floor of the machine, there were two "L" brackets with a hole for bolts, There were also two brackets on the bottom of the tub with similar holes. One pair was on the left bottom side and the other was on the bottom right.
It appeared that a bolt or some type of "dampening" connector was meant to go through to these holes. But there were no broken parts lying inside.That was my first "guess" for their purpose.
The left side (as facing the machine) "L" floor brackets and a tub bracket had been " bent" in such a way that that when the tub shook enough, the two brackets prevented the tub from moving too far. But not the pair on the right hand side. Go figure.
How it ever got this way or whether this was a "jury-rigged" solution at the factory (because they ran out of parts) is beyond me. Maybe the two brackets were meant to act as some form of "stop". But why were bent in such a fashion? And why only the ones on the left bottom side of the machine? I swear somebody bent them on purpose but that's me.
In any case, the tub had moved far enough that the bent tub bracket had slipped around the bent floor bracket. When ever the machine was on "wash" or "rinse" this "configuration" would bang against each other loudly. But it would not happen during the "spin" cycle.
I simply bent the two left hand side brackets back into a someone normal configuration (as with the bottom right floor and tub brackets) and put every thing back together. The banging sound was gone. However, you could still hear the brackets hitting each other on heavy loads. But it was not the "BOOM" I was getting before.
Eventually, the four rubber top corner "shock" springs will need replacing but at least things are quiet for the moment. But why or how the left bottom tob and floor brackets got so bent out of shape is beyond me. "Human intervention" or normal "wear and tear"?
Mark
Dec 21, 2009 | General Electric WBSR3140GWW Top Load...
Alpine CDA-7998 CD Player Logo
438 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
