Question about Motorola Mobility MING A1200
Access to aplication
I tried to delete some audio file from the file mannging aplication and after I did so the screen started to flash countinusly and sudenly stoped and I came to realize few hours later that I couldn't acces to this aplication anymore, so since then I can't open the aplication.
The sand clock shows waiting....and never get to open it.
I would appreciate if someone can tell me what to do since I leave in the gulf and I can't find a motorola technical service center.
Thank you.
Hello. my english is not so good so im gonna tri to help you. you have to enter into config and general restart. The problem id had was that i cant change the view from the elements on admin, so if it works just dont do that. hope to be helpfull.
Posted on Feb 01, 2008
How to delete notepad logs from certain files
if you are using the windows 7, and want to delete any log file which shows 'access denied' , you just need to login with your admin account and you can access and delete that file easily.
Nov 29, 2013 | Microsoft Windows 7 Home Premium 64BIT...
YahooMessenger.exe-Aplication Error The application failed to initialize properly [0xc0150002].Click on OK to terminate the application
Try to remove yahoo messenger and re-install it again.
If you can't uninstall it try this:
1) Log out of Yahoo Messenger and close yahoo messenger completely [ it should not be running under task manager as a process ]. 2) Open Start Menu >> Control Panel. 3) Double-click on Add or Remove Programs. 4) Locate Yahoo Messenger in Add or Remove Programs. 5) Click Change/Remove button. 6) Restart your computer, if it doesn't restart it automatically. 7) Open Yahoo folder in Program Files (C:\Program Files\Yahoo) and delete it. 8) Open registry through Start Menu >> Run and type regedit now navigate to the HKEY_CURRENT_USER\ Software\ registry entry, delete Yahoo, and exit the Registry.
If the above method does not work for you, try the following methods to solve the problem.
1. Open Program Files >> Yahoo Messenger and find the file UNWISE.exe file. Double click this to run it. This will un install yahoo messenger.
Jun 27, 2011 | Yahoo Messenger
I accidentally remove my "LaunchU3"
Are you sure you can't access it anymore?
LaunchU3 is only a quick launch program that comes with Cruzer flash drives. Even if the program is deleted, you should still be able to access your other files. Just go to Start -> Computer and your flash drive should be listed next to your hard drive.
If that doesn't work, then perhaps you deleted other files along with LaunchU3. In that case, you will have to use data recovery software to un-delete the files.
Try this:
May 15, 2011 | Computers & Internet
I can not install aplications in NOKIA N70
After disinfecting the mobile some programs in the mobile may corrupt. So I request you to backup all your contacts and do a softreset to your mobile.
This may be helpful to u
Jan 20, 2010 | Nokia N70 Cellular Phone
Forgot my password
i recomend contacting the manufactor but there going to want prof of perchase "its a theft prevention thing"
you could try using cheat engine 5.5 to open the drive but that has a high curve of lear ning and usage
heres a direct download link
note:viruscaning programs detect one of the hook rutines as a virus this is normal and is not to be worried about it is not a virus or a trojan
but part of the hacking featurs to sercumvent advanced anti hacking aplications that use the code cave and dll injection method
to say it simply if your the boss what you say goes and the cpu core has the highest athorites witch is what that detected virus hook dose it becomes the boss of the anti hack aplications and tells them to go bleep bleep them selves
you might find othere hacker aplications that can do what you want more directly and eficantly but thy probly have trojans and viruses in them download and use them with caution
Nov 23, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Windows vista sidebar aplication
start it again ... ask windows help for particulars
Oct 31, 2009 | Microsoft Windows Vista Home Premium with...
How to remove write protect on my usb flash drive
Maybe you are infected with a virus. Run CMD on rrun command or get to run the Windows Dos Prompt. Goto flash drive drive letter. Then type DIR/AH, this will show you list of hidden files in your flash drive usually if you get an autorun.inf you are infected with a virus. Type TYPE AUTORUN.INF with the space in between.This will show you the script if it will run an exe command usually untrusted one. Usually the autorun.inf and the linked exe is attributed to be hidden, system, and read only.
If the files in your flash drive is not so important you can try to delete the autorun.inf only. But you will gonna do this first. In its drive letter type ATTRIB -H -R -S AUTORUN.INF hit enter. Then type DEL AUTORUN.INF. trying to access the flash drive in windows screen you can get that something is cannot be found. But you could actually delete and load files into it. Or try to access the drive rightclicking it then select EXPLORE.
Hope this help. Post comments if this does not help.
May 31, 2009 | iLO (2 GB) MP3 Player
Forgotten password
Insert OS cd in drive and start reinstalling by selecting repair mode now once all files are loaded system will reboot when you see the Installing Devices progress bar, press SHIFT + F10
this will give you access to your account also you can reset all passwords
Now restart lappy and let the system boot normally without OS cd in drive
now you will come to old screen and previously configured desktop with all intact aplication and icons on desktop and it will no more ask you for password till you set a new one
Thanks and regards
Kindly rate this solution
May 19, 2009 | Acer Aspire 5315 Notebook
I have a Dell 5200series(Ithink) w/Windows XP -is 5 yrs old - 28GB on hard drive w/approx. 18 GB available.I recently added 512KRAM to go along w/existing 256K RAM - I am on dial up - Ihave used Reg Cure...
Hi 1MLucke51,
Thanks for the posting in FIXYA.
Please can you tell me the Dial up connection speed.
Please delete all Prefetch files, Temporary Internet files, Temp files , and then empty recyle bin.
How to Do:
Step 1: Delete the prefetch files from time to time.
Click on start .. type .. prefetch
Select All and delete
Step 2: Delete temp files
1. Quit Internet Explorer and quit any instances of Windows Explorer.
2. Click Start, click Control Panel, and then double-click Internet Options.
3. On the General tab, click Delete Files under Temporary Internet Files.
4. In the Delete Files dialog box, click to select the Delete all offline content check box , and then click OK.
5. Click OK.
Step 3: Temp Files
Click on start .. run .. type
Press Ctrl + A key and delete all files
Note: Skip if some of files not delete and warn by computer.
Then Empty recycle Bin
Sep 12, 2008 | Computers & Internet
Motorola Mobility MING A1200 Logo
56 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
