Question about Brother MFC-9420CN All-In-One Laser Printer
Mfc_9420cn tonner error
Even when I replace the toner it still says no toner
  • Anonymous Mar 31, 2014
    Toner replacement
  • 53 Answers
Hi firemann,
The soulution to your problem. Is that you uninstall and then re-instal your printer drivers. This is becouse you might have deleted one of your files. Try this, as in most cases like this by re-installing the printer drivers does the job.
Posted on Jan 16, 2008
Mix-it-up
  • 832 Answers
SOURCE: MFC-9420CN
There is no 9 4 2 0 cn machine from brother.
Anyway if you run a ink printer from brother have a look around here:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000053/faq000253_008.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=16
Posted on Dec 05, 2007
disastertech
  • 62 Answers
SOURCE: brother printer mfc-9420cn says to
when you open the front cover, there is a waste toner tank on the bottom right side of the printer.
Remove the tank and chuck out the waste toner, wipe the tank clean with a cloth and slide tank back in position and close the cover.
this wil resolve the message on the screen
Posted on May 14, 2008
SOURCE: Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Posted on Sep 26, 2008
  • 97 Answers
SOURCE: Error message after installing new tonner
Check the little switch/door on the left hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Posted on Dec 07, 2008
  • 215 Answers
SOURCE: Mfc 9420Cn printing but marking black line on
try making a copy off of glass. if black mark is gone, then you have to clean the narrow strip of glass to the left of big glass.
hth,
razors
Posted on Apr 15, 2009
Brother mfc-9420cn unabel to scan
I work at Office Depot. Bring it to one of our stores and we can look into it and diagnose it. Usually it is as simple as a loose toner cartridge.
Dec 14, 2011 | Brother MFC-9420CN All-In-One Laser...
If i have run out of cyan coloured toner, can i print only black somehow? the printer doesn't want to print at all (even on mono colour selection), and keeps asking to replace toner cartridge
There are few printers if any one toner ink is finished it does not print any more. So you must replace the toner or refill it then it will work.
Jun 12, 2010 | Brother MFC-9420CN All-In-One Laser...
Do i have to have toner for all colors if I just want to print black and white?
It is like he says. My 9420cn uses all the colos even if the machine just prints out received faxes. Its really annoing and costs too much.
So does anyone know a solution how to stop it from using all colors to print black?
Sep 21, 2009 | Brother MFC-9420CN All-In-One Laser...
hth,
razors
Apr 15, 2009 | Brother MFC-9420CN All-In-One Laser...
NO OPC BELT on MFC-9420cn
The opc sensor is not sensing the belt. Open the front cover and remove all the toner trays. You will see the green OPC and the sensor is located in the left upper corner. Also open the top cover and remove the OPC. Clean the sensor with a soft bristle brush. Also make sure the OPC left side is free of toner deposits. This may incorrectly trigger the OPC position sensor. Hope this helps.
Jan 14, 2009 | Brother MFC-9420CN All-In-One Laser...
Printer Says Toner Low, even when I just changed the toner
If this was an OEM cartridge, you may have received a defective one.  I'd suggest contact Brother for a solution.
Nov 26, 2008 | Brother MFC-9420CN All-In-One Laser...
Color cartridge
The Brother machine will not print if the message "Toner Empty X" ( X =C for Cyan, M for Magenta, Y for Yellow and K for Black) is displayed on the LCD. The empty toner(s) must be replaced in order to continue printing. Incoming faxes will be stored in the memory until the toner(s) is replaced.
May 10, 2008 | Brother MFC-9420CN All-In-One Laser...
Mfc-9420cn
Did u do the whole reset thing? 1 and 7 together and 2 and 8 I think, Just reset the settings also in the menu. Then do the whole maintenance Ma-Jobby, menu then mono-start then up arrow 4 times, u must be quick however.
Dec 07, 2007 | Brother MFC-9420CN All-In-One Laser...
Replace Toner Message Will Not Clear
Are you sure that it is not asking for one of the colour toners?
Was it a genuine cart?
Did you replace it before machine instructed Replace Toner ie no message or Order Toner/Toner Low was displayed?
Nov 21, 2007 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-9420CN All-In-One Laser Printer Logo
43 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
