Question about Canon PIXMA MP150 All-In-One InkJet Printer
Error Message "Waste Ink Tank Full" message - how do I resolve this?
  • Raymond Raymond Jan 19, 2008
    IHAVE SAME PROBLEM ! CAN ANY PLEASE HELP ME TOOO . INK WASTE
  • 84 Answers
Use this tool to reset the waste ink
http://www.ipt.nm.ru/iPTool.rar
Don't forget to vote!!!!
Posted on Jan 20, 2008
The following site tells you how to reset mp150/mp160 errors:
http://printertools.blogspot.com/2007/10/canon-mp150-reset-codes.html
This just resets the error message - it does not remove excess ink from the waste tank!
    Genius:
  • 2,985 Answers
Contact Canon support ot refer to
www.fixyourownprinter,com
type your printer make model in the field.
Posted on Jan 16, 2008
4 Suggested Answers
Beni S-P
  • 1006 Answers
SOURCE: waste ink near full error message
Canon Error Codes
L5000,5500,7000,8000: To enter service mode Data Registration, #, Ram Clear is under #8 clear
Faxphone 20 ram clear
Turn off the power switch
Turn off the memory protect switch (located on the bottom of the machine)
Turn the power on
Press function # 2 0 start
Turn the power switch off
Turn on the memory protect switch
Fax L770 fuser gear wears out easily under heavy usage. White gear with 2 sets of teeth.
Inkjet models such as the B160 will hold faxes in memory and refuse to print if excess ink has accumulated on the pad under the cartridge's nose. Remove the cartridge and wipe up excess ink with a cotton swab.
Posted on Nov 02, 2007
  • 49 Answers
SOURCE: Canon printer i 475D
This may be worth a try
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Jul 03, 2008
taran_2005
  • 10515 Answers
SOURCE: My Canon Pixma MP780 has
The reset procedure for the same is explained below :-
The absorber is a small sponge like pad inside the machine underneath the ink cartridge cradle. It sits underneath the cradle when the cradle is all the way to the right inside the machine. To fix this problem that pad needs to be replaced. Some machines will have a tank instead of the sponge. It is located in the same place. To fix that you would sinply need to remove it and then empty out the tank.There is no step by step guide to do this you would need to dissasemble the entire machine if it is a tank and not a sponge. If this is the first time it has ever occurred you can simply reset the error as there are normally 2 tanks. To reset it follow these steps.
1) Press the following keys in sequence: Copy-Menu-Scan-Copy-Scan.
The display will say:
SERVICE MODE
#1 SSSW
2) Press the > key (also labeled +) six times.
SERVICE MODE
#7 PRINTER
3) Press OK.
#7 PRINTER
#1 SSSW
4) Press the > key (also labeled +) four times.
#7 PRINTER
#5 INK ABS CAPA
5) Press OK.
SUCTION
XX (where XX is how full the waste ink tank is as an integer percentage)
6) Change the XX to 0 by entering 0.
SUCTION
0
7) Press OK.
The display will momentarily say:
SUCTION
DATA ENTRY OK
and then will quickly change to:
#7 PRINTER
#6 CDR ADJUST
8) Press the Stop/Reset button
If that doesn't resolve the problem, you need to get the printer serviced for the same.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 16, 2011
Error message "service required...parts inside
This is a very common problem and is basically your printer reaching a point where an internal counter has tripped. The primary reason for this is the printer has guesstimated that the waste pads are now full and need changing.
Resolving it is pretty simple...
You can either take it to a service centre (assuming they'll be able to service one as old as the R220) and get them to handle it for you.
OR..
Do some searching on the subject of fitting an external waste ink tank. You'll also need to reset the waste ink counter which can be handled using the A10_IPR utility that Epson released for North American customers some time back.
For more information on your specific printer along with instructions on how to fit an external waste ink tank this link should help.
Dec 08, 2010 | Epson Stylus Photo R220 InkJet Printer
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
I own a canon w8200 pigment large format printer. I replaced two cartridges, Magenta and Yellow. The printer did a nozzle check that seemed to take too long. I then received a 'waste ink tank full'...
<Remedy>
1.Waste ink absorber
Use SERVICE MODE>COUNTER>PRINTER>W-INK to check the waste ink
absorber. Replace if the waste ink level is near the limit (14400).
After replacing the tank, perform SERVICE MODE>INITIALIZE>W-INK.
Apr 04, 2010 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
5) Select OK
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
I have a Canonmp390 printer & a message keeps
Error "Waste Ink Near Full"
Cause : The waste ink tank (which holds the ink used for print head cleaning) is nearly full.
Action : Contact the Canon Customer Care - Center.
Have a good day.
Dec 03, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Waste ink tank nearly - message
it won't stop until the ink absorbers are replaced and the error reset in canon diagnostics. A shop repair, around $100.00
Jul 15, 2009 | Canon SmartBase MP390 All-In-One InkJet...
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Message "wasted ink tank near full" on Canon Multipass F80
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 17, 2009 | Canon MultiPASS F80 All-In-One InkJet...
I get an error message on Canon i960 printer that tells me the waste ink tank full. How can I empty this myself?
Read it all here.
Scroll about half the page, to:
WASTE TANK ALMOST FULL or FULL ERROR MESSAGE PROBLEMThere is explained how to get rid of the error message very easy, and how to clean the waste ink pad manually. The latter seems not to be necessary, though.
Mar 27, 2008 | Computers & Internet
CANON MP730 ERROR MESSAGE 343 WASTE INK FULL
1-press the "menu" key
2-press the"copy" key
3-press the"#" key
scroll thru the menu heading until you come to "counter"
press "ok"
press "menu"
and select "clear all" it will ask you to "please wait"
then press menu two times
restart your printer
it will work
Feb 22, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
419 people viewed this question
old marine
old marine
