Question about Xerox Phaser 8500/SN Color Laser Printer
Please Help On startup the printer begins to warm up. When it gets to 20% of the process it gives an error message "error 07,010,43:4502 "
    President:
  • 2,072 Answers
That is an error caused by the print head not being able to move freely.
Most likely some ink has seeped into the staineless steel pivot block that allows the print head to move from home to print posption.
4 most likely problems.
1. The staineless steel print block is contaminated by ink.
2. The machine somehow was unpluged or lost power with the drum wiper between the drum and print head and is now tacked to the print head.
3. One of the cables has moved and is hindering the proper movement of the print head.
4. The drive motor gear chain has slipped out of timing. So they say. That can cause the problem according to documentation. But I have never seen this motor move out of proper timing.
To decreas the likelyhood of this problem in the future. Make sure the printer is LEVEL, front to back and side to side to minimize the possibility of the liquified ink leaking out of the print head.
A print head failure is pretty much unlikely with this code.
Posted on Jan 16, 2008
Gateway laptop error
Which operating system ?
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate.
Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files.
It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen
Click the "Start" icon in the lower-left corner of your Windows 7 home screen.
Click "All Programs" in the Start menu, then click "Gateway".
Click "Gateway Recovery Management" to open the Gateway Recovery Management program.
Click the "Restore" header, then click "Restore System To Factory Default".
Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes".
Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart.
When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes.
Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer.
Your computer will reboot.
After the computer restarts you will need to configure Windows 7 with your personal preferences.
Recover at Startup
Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program.
Click "Restore System From Factory Default".
Click "Next" to begin the restoration process.
or if still no joy
http://www.almuseo.com/download-repair?Windows 7 0xc0000185for Windows 7 0xc0000185 and associated problems.
Windows 7 0xc0000185 error message codes are almost always caused because of missing system files inside your Microsoft Windows operating-system.
When you've got Windows 7 0xc0000185 error message then we suggest that you perform an error scan.
This article provides related information that explains the best way to repair your Windows Windows 7 0xc0000185 error codes either by hand and automatically. Additionally, this guide can help you to fix most regularly occurring error code messages connected with Windows 7 0xc0000185 error code which you might possibly get.
Jun 03, 2013 | Computers & Internet
Xerox phaser 8560 color printer has Error: 07,007,40:41:424 please help
Errors beginning with 7,007 usually indicate the process motor. According to the service manual you should first inspect the drive gears for ink spills and inspect the wiring to the printhead. If you don't notice anything replace the process motor and gearbox (part# - 005K12670). You can order one here. After installation you need to home the process gears. Here is a video we made to show you how. If you need help installing the process motor I should have a video of that up later this month. Or give us a call for free technical support 1-800-367-4836.
Apr 19, 2011 | Xerox Phaser 8560DN Laser Printer
Printer won't print labels
Try resetting the printer:
Note: it will erase all network settings.
Turn the printer off, press and hold the GO button, turn the printer back on, continue holding the GO button for at least 10 seconds, but for fewer than 20 seconds. After the Go, Attention, and Ready LEDs turn on, release the GO button. During this process, the Attention LED will turn on, the LEDs will begin to cycle, and the unit will perform a cold reset until the printer returns to the Ready state.
NOTE: If either the Go or Ready light turn off or no LEDs turn off before the GO button is released, repeat the process.
For PCL XL error: try to reinstall the printer drivers.
Oct 11, 2009 | HP LaserJet 2550L Printer
Cant download update driver for X3580 error message 1001
Try removing the command to startup the lexmark printer monitor from the startup file. Just run "msconfig" and uncheck the command. Then reboot and try the update again.
Jun 20, 2009 | Lexmark Office Equipment & Supplies
Keeps restarting
I do not know about the screeching part, that could be part of the problem or completely independent of the problem. When my machine kept repeating the "startup" process, it was because my bulbs went out. The printer then would never get warm enough to melt the ink to begin printing, so it would just keep restarting, and restarting the warming up process. One way to tell is to take off the side cover. Then peer into the side and see if you see a bright light - which would be your bulbs. I have no idea though what to tell you about the screeching thing.
Jun 03, 2009 | Xerox Phaser 8200 Laser Printer
New Printer Installation Error
ISSUE: When trying to install an HP LaserJet P2015 printer, a MSVCR80.dll error message is received.
SOLUTION: To resolve the issue, complete the following steps:
  1. Before installing the printer, disable any Anti-Virus and/or Firewall software. To disable the Anti-Virus and Firewall software in Microsoft Windows XP and Microsoft Windows 2000, press the Ctrl+Alt+Delete simultaneously to enter the Windows security screen. Then select Task Manager , select the Process tab, select Anti Virus and/or the Firewall Image , and end process on the software.
  2. Disable XP firewall. To disable the firewall in Microsoft Windows XP, right-click My Network Places , select Properties , right-click Local Area Connections , and then select Properties . Select the Advanced tab and remove the checkmark from Internet Connection Firewall .
  3. If the issue persists, before trying to install the printer, we suggest you complete follow the steps:
    1. For system clean boot to perform, click Start , click Run , type msconfig in the Open box, and then click OK .
    2. On the General tab, click Selective Startup , and then clear the Process System.ini File and Process WIn.ini File , and Load Startup Items checkboxes. You cannot clear the Load system Services and Use Original Boot.ini checkboxes.
    3. On the Services tab, select the Hide All Microsoft Services checkbox, and then click Disable All .
    4. 4. Click OK , and then click Restart to restart your computer.
    5. 5. When the system restarts, click Start , and Printers and Faxes . Delete all the printer icons.
    6. 6. Click Start , click Printers and Faxes , click File , click Server Properties , and then click the Drivers tab.
    7. 7. Select all the printer drivers individually, and click Remove . Remove all the drivers one by one.
    8. Click the Ports tab and delete the listed TCP/IP ports individually by selecting the Port and clicking Delete Port .
    9. Click OK , and then restart your computer.
    10. When the system restarts, begin the installation process. You may insert the installation CD into the CD-ROM and follow the onscreen installation steps to install the printer locally.
      NOTE: Do not connect the printer to the computer until prompted to do so during installation.
Oct 28, 2008 | HP LaserJet P2015dn Printer
Kernel driver error message
If your able to put a motherboard out then
this will be right up your alley,,,,
After the reveiws I have read relating to this error,
have a look for yourself......
http://www.file.net/process/aslm75.sys.html
I beleieve its worth formatting the unit,
after saving the important stuff you should
formatt and start again,
30 min to load a system from a disk,
less if theres a back up image on a partioned drive,
fresh install,only way to go.....
no need to fix anything,
most important,SP2 updates give functionality
no more head aches,
WORKING,
Let the formatt begin.
enjoy,
Let me know the out come thanks
Jul 21, 2008 | ASUS A7V8X Motherboard
Xerox 8500 Error 07,101.43:20955
That has to do with the process drive gear box. May be mis timed or a gear broken.
Apr 11, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8500/SN Color Laser Printer Logo
171 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
