Cd player not working
Hi, I have an old Panasonic cd player SA-AK28. It is a 5 disk player. At the moment when I try and play a cd it keeps alternating between cds saying there is no disk which is not the case. I am probably going to upgrade soon anyway but would still like to know if this is a simple problem to fix. Could this be a problem with the laser?
  • 70 Answers
  1. its eye unit may in trouble, clean eye by using a eye cleaning cd
  2. eye alignment is failed, adjust the eye by adjust the screw on the eye
  3. cable may loose contact, re fix cable, check cable replace cable if necessary
  4. low power supply problem, check supply voltage, if it low simply add a filter capacitor of 4700uF/40V accross it.
  5. some time its main board may problem, check and replace it
Posted on Jan 16, 2008
Panasonic SA-AK29 Disc Drawer won't stay closed.
It is quite possible that the timing within the mechanism had changed. Since the timing is quite important to activate the mode switch to triggerr the sequential action of the mechanism to proceed accordingly, a small change in any of the links can change the mode to keep away from resetting. Please open the set and check if there is any foreign particles lodged into the dirve mechanism. Clean and proceed. Check carefully for any sensors that are out of sync.If you are not sure do not attempt but try tomake a small correction to complete the loading so as the complete the mode. If so the fault might clear. Hope this helps you out.Good day
Jul 20, 2010 | Philips Audio Players & Recorders
Panasonic SA DK10 starts reading discs, gets to 00 and then stops
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case this don't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 08, 2010 | Panasonic SC-DK10 System
Panasonic SA-PM19 5 disc player jumps around, starting at or near first track, plays a little, then jumps a good chunk, plays a little more etc, until it reaches (quickly) the end of the disc. It does this...
Could be a CD defect, but probably just dust inside. Try canned air, or connect IPOD after you convert CD's to MP3's or other player to AUX port as a connector as a work a around. Splicers available online if you already have a TV connected.
Mar 20, 2010 | Panasonic Audio Players & Recorders
The SA-1 cannot read CD and Display is off
lens is dirty ........clean the lens using the lens disk cleaner...........still problem continues the laser head is not picking up the disc...........need to replace laser assembly.......
Feb 04, 2009 | Marantz SA-1 CD Player
Hi, I have a Panasonic SA-EN9 digital radio / CD player ect shelf system. I want to play music from an mp3 handheld player through it, and I see that there is an AUX jack in the back of it. I can connect...
Hi, I have the Panasonic SA-EN9, and if you plug your mp3 player (I have and ipod) into the auxiliary socket you should be able to play it by pressing the AUX button on the remote provided.
Hope It Helps :)
Jul 11, 2008 | Audio Players & Recorders
Problem playing DVD's
bring (cd cleaner)cd from near radio shack and run it until you get good result.
Jul 05, 2008 | Panasonic SA-HE90 Receiver
Panasonic stereo with 5-cd changer
Hi, I have a Panasonic SA-ak25 system. I played one cd then inserted a second. When the second cd had finished it ejected but the first cd is still in the player, When i try to eject it the lights start to flash and it always stops on no (4) can anybody help. Bob.
Jun 15, 2008 | Audio Players & Recorders
308 people viewed this question
 Grubhead
Grubhead
