connect computer to network install canon color network scangear, select printer ip in this software. now you need scanning software. I'm using freekapture. place document in printer scanner. click scan button on printer.open freekapture and start scanning
Dear Mokhtar,Error code E197 indicates that laser scanner does not work properly. It's seems that you should try to replace this parts (Laser Scanner Assembly). Please download the following piece of IR2022 parts catalog to see detail of laser scanner assembly:Laser Scanner Assembly I'm sorry for being late responding your problem and you don't have to pay for this :). Regards,Xanda
check the drum insert flag in the drum unit(front side).it has to be intact as it has to match the sensor when the drum unit is inserted. u can see it when u insert the drum unit it is it at the front of he machine.u can also bypass it by placing a paper int the sensor
MEMORY IS FULL / SEE MANUAL (alternating messages) The memory is full. You may have too many messages recorded in the answering machine. To erase messages, see below. This may occur during fax reception if too much data is received before the pages can be printed out. If faxes have been received to memory because printing is not possible (an additional message will indicate the problem), resolve the problem so that printing can continue (see Substitute Reception to Memory on page 66). If you are attempting to transmit from memory, see If the memory becomes full on page 57. If you are copying, see If MEMORY IS FULL appears on page 67.
Erasing received messages: It is important to erase received messages after you listen to them to ensure that the memory does not become full. ? Erasing all messages: To erase all messages, press FUNCTION, DELETE, and then START/MEMORY. ? Erasing a single message: To erase a single message, press DELETE while the message is being played.
If the memory becomes full while the document is being scanned, MEMORY IS FULL and SEE MANUAL will alternately appear in the display. ? Press START / MEMORY if you want to transmit the pages which have been stored up to that point in memory. The remaining pages will be ejected from the feeder. After transmission, the memory will be cleared and you can transmit the remaining pages. You will also need to transmit the page which was being scanned when the memory filled up. ? Press STOP if you want to cancel the entire transmission.
when saying memory full that does no mean the text messages memory is full it means the phone's memory is full, the messages are saved on you sim card so try deleting some app on you phone
Hi, Welll i too have a sony erricsson mobile.Actually Son phones has a limitation that only around 200 msgs can be stored in ur mobile.Although u may have free memory in ur phone i.e ur phone memory is not full but ur message memory is full.One thinh u can do is to store some messages on ur sim card.Sim card have some memory like my sim card can store upto 20 messages.Otherwise u dont have any choice but to delete the messages.
