Question about Lite On (  SOHW1213SRETAIL) (SOHW1213SRETAIL) DVD±RW Burner
Shw-160p6 problem with tray
Yes my drive is messed up the tray dont open when i push the button but you can hear it trying to and i have to hit my pc to get it to let go or i have to us a pin or something to put in the little hole you know . any idea what i should do this rom is not that old maybe a year or less thanks
  • 1,003 Answers
Posted on Jan 17, 2008
How do i eject a disc
If the tray fails to open when hitting the eject button on the face of the drive; take a paper clip, straiten on end push it into the small hole on the front of the drive. This will eject the tray and allow you to use the Reader/Burner. Try grabbing the tray and move it in and out aggressively, and do that about 10 times to loosen up the drive motor and clean out grime that collect on the internal parts.
Jan 08, 2014 | Gateway Computers & Internet
My acer x1700 cd drive wont open.. i can hear it attempt to open. i do not have an emergency bottom or push out hole. please help many thanks
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you continue having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Oct 23, 2012 | Acer Computers & Internet
My dvd drive won't open.
In the front of the loading tray you will see a small pin hole, get a fine jeweler screwdriver or a needle push in until you hear click the door will pop open allowing access to your cd/dvd disc, if the driver won't work it will probably have to be replaced.
Feb 01, 2011 | Dell Computers & Internet
My disc tray will not open and sounds like it's running but locked.
On the front of the tray you should see a small pin hole, get a fine jewelers screwdriver or needle, next push it in until you hear a click, the door should pop open, now pull it out all the way and check for any debris or possible broken belt or slippage under tray. If you can't find anything try a disc to see if it will work, if yes! try the eject button if no! remove disc as outlined and have it checked out.
Jan 22, 2011 | Compaq Evo D510 PC Desktop
Shw-160p6s disc drive will not open
You can open manually using small metal stick (metal paper clip).
Turn off PC, poke small hole (under the tray) gently. Check the rubber ring (like fan belt that goes to electrical motor), it might too loose.
Apr 25, 2010 | Gateway GT5220 PC Desktop
Drawer on cd drive won't open model is gateway digital media center gm5260
There are a couple of possibilities here, first it could just be stuck. If you hit the eject button and light flashes, there may be a stuck factor here. Look for the very small hole on the door by the eject button and push an opened paperclip in the hole, this will trigger the manual eject mechanism. With the tray opened feel the way the tray moves along its geared slide. If it seems too tight or it sticks there maybe something mechanical that has happened to it. Try to close it again and try the eject button and see if it will cycle. Also try to right click on the drive itself (Open "My Computer" to view the drives) and click on "Eject" and see if it triggers the command.
Jan 30, 2010 | Gateway GM5260 PC Desktop
When i push the eject button on the console, the disc tray doesn't come out
Do you hear a loud "Thunk" when you try? It's very likely that you have a drive that has a magnet that's too strong. Many 360 drives suffer from this. With a balled fist hit the top of your Xbox right above the DVD drive firmly. This should cause the tray to open.
Jan 09, 2010 | Microsoft Xbox 360 Console
The door on my cd rom cant not open when i eject, i dont hear the motor but the light shine just at start up
Look on the front of your cd-rom, there should be a small hole somewhere just under the tray portion. Turn off your machine (to avoid possible short-circuit issues) and use a thin piece of wire (ie: a straightened paper clip) and insert it into this hole. Push it gently, you will be able to feel the unit unlocking itself and the tray will open slightly. Now you can use your fingers to pull the tray open. Be gentle when opening, you don't want to mess up the gearing.
Oct 07, 2009 | Computers & Internet
Cd drive stuck shut with disk in it how do i get it open now
use a paper clip fold it out and push it straight in carefully into the eject hole in the cd drive. It is a small hole on the cd drive usually close to the eject button. You will feel a release on the inside. When you push it you will hear it/feel it eject. Don't push real hard as you don't want to bend the paper clip and get it stuck in the hole
Aug 08, 2009 | Fujitsu AMILO Pro V1000 Notebook
I got a cd stuck in the cd/dvd drive for my gateway laptop- i dont know the model. tried to hit eject button and ejecting through computor and it will not open. what do i do?
All CDs & DVDs have a tiny hole on the drive tray.
Get a paper clip, straighten the paper clip and insert it into this hole and push the paper clip in gently, the tray will release and pop out, then you can remove your disc.
You can do this without the laptop being powered up or powered down.
Feb 21, 2009 | Gateway M305CRV Notebook
Lite On (  SOHW1213SRETAIL) (SOHW1213SRETAIL) DVD±RW Burner Logo
52 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
