Question about SAMTRON 55V 15" CRT Monitor
Samsung 45bn H output transistot over hating and burning out after a fewminits
Samsung 45bn H output transistot over hating and burning out after a few minits . Plz Help me for solve this problem
    Genius:
  • 1,003 Answers
THE MOST ECONOMICAL SURE FIRE FIX IS TO REPLACE YOUR MONITOR WITH A QUALITY LCD SCREEN IT UTLIZES 50% less electricty AND RUNs A LOT COOLER.
IF THE HORIZONTAL OUTPUT TRANSISTOR IS BAD MOST LIKEY THE POWER CONTROL BOARD IS GOING BAD you may also have a bad resistor or diode allowing to much current on power control board
Posted on Jan 16, 2008
Sony kv g21p2s tv h out burn after 1 minit or fly back burn y that
Check the frequency at the base of horizontal output transistor. If it is abnormal [High], this kind of fault can occur. If so, main jungle IC should be checked.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 11, 2014 | Televison & Video
I test my crown amplifier 3600vz a few minites then i stop couse verry hot i discover i open the back panel i saw resistor12 and resitor14 burn,i ask what is the promblem,the value of r12 and r14 is...
The ouput drivers have failed and along with the heavy current drain the resistors burnt off . So before the resistors are changed the entire section of the predriver and output section must be checked before new outputs are installed.
test the amplifier with a series voltage regulator and is there is heavy load drain then shut down and recheck till the drain limit is maintained to confirm the correct working of the amplifier.
Sep 09, 2011 | Crown MA-3600VZ Amplifier
There is a permanent broad coloured stripe down the centre of the screen - how to get rid of it?
LCD display may have moisture on tinoxide which can be burned off in low humidity room. LCD tft may be leaky, which can be burned in by standby for a few weeks. Video output semiconductor IC may be needed burn in for a week. Most of these problems are due to moisture in the air, and lack of use of the TV. Have power on 24/7 may solve the moisture problem.
Oct 01, 2010 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Samsung (samtron 5Ei ) rebooting & EMI problem at times it is O.K.
Check 5 v at 7805 output and change Memory IC (EEPROM).
Check SMPS o/p voltages
Sep 20, 2008 | SAMTRON 55V 15" CRT Monitor
Problem with the samtron 45bn monitor
sounds like your video card went out simple check of this
if you have another computer that works hook it up to its computer if screen comes on it will be your video card in the comp now if the screen still doesnt work it will be the cable the pins in the end has some how bent or come loose this will require a service tech electrician to repair simple quick job
May 25, 2008 | Computers & Internet
Samsung 45bn
hi... there's a resolution problm with samtron45Bn with win xp.
Pl.help to fix this pblm.
May 22, 2008 | Computers & Internet
SAMTRON 55V 15" CRT Monitor Logo
121 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
