Question about Emerson MW8987B/W Microwave Oven
Door latch on Emerson microwave oven
The door latch on my microwave oven will not close. It seems the latches on the door do not catch when closing the door. Any solutions?
  • 17 more comments
  • gramilina Jan 23, 2008
    The model no. is MW8992SB, 900 watts.
  • gramilina Feb 10, 2008
    Where do I get a new door assembly for this microwave oven?
  • Anonymous Mar 11, 2014
    Drive belt loose 2750 York pacer
    Tomb Raider. Your card or driver doesn't support DirectX9.0c 3D Acceleration
    why gas gauge goes pass all the way of full thank
    1999 dodge Durango where is tire jack
    1990 Honda accord brake fluid lReservoir emptied overnight 1990 Honda Accord brake fluid reservoir empty overnight
    I have a 2004 Chevrolet 1500 extended cab I just put a new motor in the truck and now it's throwing a security code and wont turn over or anything Any ideas what could be wrong?
    fast idle 1989 chev 3500 pu
    I forgot my PUK CODE. How do I retreive it
    what is dowel pin position on intake and exhasut cams, up, down or both
    Setting up cell phone for voice calls
  • Anonymous Mar 12, 2014
    I bought a replacement remote control for my PAnasonic DVD Home Theater SA-T720 but it is not working
    some times it dies while driving it and some times it wont even start. If you try to start the car and it wont start you have to let it sit for a while and then try again and then it will start just fine.
    OKI microline 280 elite 9 pin printer
    How to stop "Thanks for choosing Karbonn Mobiles. For any further details/help please write to support@karbonnmobiles.com or call 18001024660 (TollFree)" due to this message daily cutting 4 Rupees last two monthes. please sir help me.
    I have myob account edge 6 and want to run it on mac mountain lion
  • Anonymous Mar 14, 2014
    MOdel NN-H965BFX
  • Anonymous Mar 17, 2014
    Door uneven
    Master:
    Sergeant:
  • 440 Answers
U will need new door asemble to relly fix it ok thx nick
Posted on Feb 10, 2008
  • nick helpap
    nick helpap Feb 10, 2008
    ermerson dealer who sels parts will be able to order u one the fastest ok and safest way
Door catch is stuck in unit so door won't close and microwave won't work
No, the only way is to take it to a technician. The door and catch has about 4 safety interlocks to stop you getting microwaved. The case has security screws only the techs can undo.
Apr 07, 2016 | In Microwave Ovens
Why door will not stay closed
Latch or catch is either broken or misaligned. Find out which and repair or replace.
Aug 10, 2014 | Samsung SMH1816S Stainless Steel...
Latch doesn't always catch so microwave won't run
Well I think you need to clean and pray the latch area with silicone spay lubricant and work the catch a few times to work it into the mechanism and see if that makes any difference but make sure you wipe off any surplus silicone spray
Jan 02, 2018 | Microwave Ovens
Neff H7871 oven door does not stay closed. Catches do not appear to be working
The door latch is either cracked or broken.The door when gets closed the door latches clicks.But if the door latch is loose or cracked it will not click and door will not close.The door needs to be disassembled and the door latch has to be replaced, if the latch is cracked.Also to check the latch from inside the door needs to be removed.-------- This will help.thanks.Helpmech.
Jun 29, 2011 | Neff Microwave Ovens
Hello My name is Mohamed. I have a sharp microwave oven model R-316FSU, I am having trouble opening the door. The latch seems to stick. How can I fix it?
Door catches.
One of the latches may be damaged or misaligned and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When the door levers are in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Mar 21, 2011 | Sharp R-316FS Microwave Oven
The the top latch on the door is not closing the door and preventing the microwave from working. Can you tell me how I can get it fixed?
Remove the cover and take a look at why it is not latching. I suspect there is a catch that is broken. Find replacement latch at your local appliance parts store.
Thanks for your question today.
Mar 02, 2011 | Emerson Black Microwave Oven
Microwave will not cook/start when start button is pressed.
You can get the latch itself from either partstore .com or repairclinic .com
Apr 19, 2010 | Emerson MW8168B Microwave Oven
Door does not secure when closed
Hi , Either you have a faulty door interlock switch(es), or the door latches (on the door) have been damaged and will not activate the interlocks. either way, you have to be conversant with adjusting microwave latch assemblies once the repair has been effected AND THE USE OF AN OVEN LEAK DETECTOR IS IMPERATIVE for final testing or the end user will be subjected to harmful levels of microwave radiation.
Jan 05, 2009 | Panasonic NN-S753 Microwave Oven
Front door closes on a model R-1610-11-12 but light does not go out and microwave cannot be started up. Door does not seem to latch in place. In lower door latch inside the microwave I can see a plastic...
hi check that the door catch is locking into place maybethe locking mec is not engaging or triping the micro switch ,if it does n't trip the switch it won't turn light off and unit won't work
cheers grant
Oct 22, 2008 | Sharp Microwave Ovens
Emerson MW8987B/W Microwave Oven Logo
946 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
