Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
Lambda doesn't record, though it seems ready to go
I just got a lambda. everything's in the right order. at first, there was an issue with recording in cubase that i solved by getting drivers through the lexicon website. now, i set it up, made sure to make sure it was in the devices, click the red record button, connect my keyboard/bass/microphone in the proper line 1 and line 2 inputs on the back, set the tracks to the proper line, plug my headphones into the lambda, adjust the volumes and play the instrument to set the peak level, hear it in my headphones, then i click record and it starts to go, and i play something, but no waves, just a straight line, no matter what i do, no matter how i connect each device into the lambda.
simply, it won't let me record. it isn't registering the connection of the instrument through the lambda to the computer. i don't know where it gets lost in between, but a straight line is not what i played. promise.
any solution to this one?
  • 4 more comments
  • BUMMERDEAL Jan 20, 2008
    yeah i have the same damn problem too i hate this thing so far im pissed it worked for a coll new york minute but now it says the thr MIDI device is not digitally signed you aveing the same issues??
  • migmog Mar 30, 2008
    I have the same problem - I've set it up as described but in the Inspector Window it never gives me the chance to select an input from the Lexicon Lambda!?
    Cheers,
    Migs
  • solarkidd Apr 10, 2008
    I have the same problem?
  • Anonymous Jun 05, 2008
    I have the same problem. It seems right on the recording process but when trying to rewind and play it, nothing comes out just straight line.
  • Anonymous Dec 16, 2008
    I have the same problem, everything is setup correctly but when I start to record no wave, only straight line!
  • Anonymous May 09, 2009
    just got this thing and have same problem ...everything set up right...really thinking this sucks...
You need to go to the "control panel" on your computer.....click on sounds and audio devices, then hit the "audio" tab...make sure the lambda is selected on the recording and playback device....then apply...this should take care of it
Posted on Dec 22, 2008
SOURCE:
I installed the lexicon lambda with the disk provided but when i put my mic on the mic input it doesn't record... what should i do? please help!
first thing to do is check your sound and audio settings, goto control pannel,then, sound/audio setings and see if everythings set up properly
Sep 19, 2011 | Lexicon Lambda Usb Desktop Recording...
Lexicom Lambda is not working! New user
right click my computer goto properties-harware-device manager then right click the lambda click update driver browse it with ur cd driver...hope this help
Jan 21, 2008 | Lexicon Lambda Usb Desktop Recording...
I am totally lost!! All I have is the lambda lexicon and cubase LE4 on my desktop.Apparently it is not set up correctly. I want to record guitar and voice I have sound on lambda through mike and guitar but...
All it needs is a USB connection. You'll need to go into Cubase device setup and make sure your lambda drivers are selected. Then create the audio channels in cubase with the inputs set as the inputs you're using for guitar and mic. There is a monitor button right next to the record enable button that needs to be enabled if you want to hear playback from your computer.
Feb 20, 2010 | Lexicon Lambda Usb Desktop Recording...
I Installed the Lexicon Lambda and followed all of the instructions to the letter. I can hear sound out with no problem, but when I record, it records from my laptops internal mic. Thus, everything in the...
You will need to go into your sound properties, you can do this by clicking on the speaker Icon thats down by the clock (lower rights hand side of your screen) that should bring up sliders for everything.
Their is also other options and advanced options you may need to enable that could be specific to your devices. but the main thing here would be for you to disable the one mic and enable the one you want and also possibly lower its sensitivity levels.
Apr 17, 2009 | Lexicon Lambda Usb Desktop Recording...
Lexicon lambda no sound during playback
AFTER you open a new poject go to "Devices" then "Device Setup" click on "VST Audio System" then on he right side where it says "ASIO DRIVER" make the selection say "Lambda ASIO" then click OK
Jun 05, 2008 | Lexicon Lambda Usb Desktop Recording...
Distortion
It's because when you recording your get sound from Lambda!!! But PC can't reproduce that quality! Try to download driver or update which will allow you to achieve what you want.
Lexicon lambda
push the monitor button to go mono instead of stereo.
Oct 11, 2007 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
480 people viewed this question
Top Lexicon Computers & Internet Experts
Tony Raia
Alun Cox
Thomas F. Schneider
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
