Question about Sharp AR-5316 Advanced Digital Imager Copier
What's U2 code and method for solution
My coppier is sharp Ar-M205, when I swith on power, panel dísplay U2. please help me
  • Anonymous Jul 29, 2008
    I am facing same problem. I had tried inserting cartridge many times but to no avail.
    the code in my copier is U2 40 Pl. suggest me solution
5316 u2
Posted on Apr 06, 2008
  • 2,072 Answers
U2 can have several indications.
The most likely one is that the chip that is on the back of the toner cartridge is not seated properly or has failed.
Try with the machine off, removing and inserting the toner cartridge several times to clean the contacts, next step is to try a new toner cartridge.
There is also a connector on the back frame of the machine that may be dirty or going bad.
Posted on Jan 16, 2008
In the code "pound star clear star sim 14" what key is sim?
To enter service mode on the AR-M205 you need to press the keys: # key, interrupt key, C key, interrupt key.
then enter 14 & press start.
I assume you are trying to reset an error code.
If you have an error code U2 then enter 16 & press start.
Hope this helps.
Oct 13, 2017 | Sharp Office Equipment & Supplies
I want sulving this problem call for service. code : u2-40
Here is a list you can find a copy of all the error codes
Seems like a board error. The machines are almost 12 years old now and parts are very hard to come by. You may be able to pick up a used Sharp AR-M205 off ebay or you may want to consider upgrading to a newer machine.
Sharp Copiers
Nov 06, 2012 | Sharp AR-M205 Copier
Sharp m205 error u2 Problem, what does mean?
press 0 U2 if 04 occurs EEPROM read/write error (serial communicationerror) if 11 occurs Counter check sum error (EEPROM) if 12 occurs Adjustment value check sum error (EEPROM) if 40 occurs CRUM chip communication error
Jan 11, 2011 | Sharp AR-M205 Copier
How to reset u2-40 for sharp AR266 photocopier
Hello sir; I'm not recognize this model number please double check,but I give you closer one to reset;
1, press "program", "interupt", "clear", "interupt".
2, enter 16 press start.
3, turn machine off and back on .
Jun 02, 2009 | Sharp AR-M205 Copier
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
We have a Sharp copier AR-M205, and it keeps giving us the U2 code and we have tried to reset it and it doesn't work.
u2 code .just check what is the sub code by pessing start key.if sub code is 01 thats counter sum check(memory problem)if 04 eeprom problem if 40 reset u2 just do clear ,exposure,clear,exposure,16,print.code will remove .by mian jee
Dec 05, 2008 | Office Equipment & Supplies
H4 flashing
to access the service mode.
Nov 14, 2008 | Sharp AR-M205 Copier
Printer displaying an error message: 2U
There is a long list here for the U2 code so if you let me know I will tell you what it means..
Again what is the Last part of the Code?
If it is U2-40 code, it is a Crum Chip, Take the toner out clean the end of the toner cartridge, there is a chip, a small plastic connection piece with bronze/silver wire on it.
Or replace the toner cartridge.
You will also need to clear the code with simulation 16.
Turning the machine off might work but, not usually.
Oct 28, 2008 | Sharp AR-M205 Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
170 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
