Question about Ecoquest Flair Air Purifier
How to Clean The Unit
I find our Flair very effective. The problem is I cant figure out how to clean the inside (fan , grill etc.). Do I need to unscrew everything from the back? Will I be able to bring it back all together? Will appreciate your suggestions and/or experiences.
There is a screw on the bottom of the unit. When you remove it, the whole insides can be slid out. Then just blow the dust off with canned air. Wal la, you're done!
Posted on Feb 11, 2008
Cleaning inside of system
Call (336) 499-2505 and they will email you cleaning instructions for free. Tell them you were on Fixya.com.
Jul 16, 2012 | Ecoquest Flair Air Purifier
How do you clean motor on Flair? Fan will not turn
The motor shouldn't need cleaning that would prevent it from turning on. When was the last time you cleaned the machine?
Jul 26, 2011 | Ecoquest Flair Air Purifier
Running but does not have that clean air smell.
If the unit has not been cleaned regularly or recently, that is more than likely your problem. The interior is simply covered with dust. Clean the unit according to the Owners Manual instructions and you should be getting the ozone smell again. If the unit is more than 5 years old, you may need to also replace the plaques inside. These can be purchased online from the manufacturer.
Hope this helped to solve your problem.
Mar 09, 2011 | Ecoquest Flair Air Purifier
HELLO AND GOOD MORNING I HAVE A FLAIR AIR
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Mar 18, 2010 | Ecoquest Flair Air Purifier
How do we clean the fan on our Flair?
take the grill of and get a soft cloth and lubricate the center of the motor
Mar 17, 2010 | Ecoquest Flair Air Purifier
How do I clean the metal screen? Do I need to replace any filters at any point?
if the metal screen is removable, run under warm water and gently brush with damp rag
if no removable, unplug unit, wipe clean with damp rag
May 29, 2009 | Ecoquest Flair Air Purifier
Ecoquest Flair Air Purifier leaves black residue on walls and...
The black residue is what is in your air. The reason for it to cling to the walls is the Ionization process that the machine creates. The ionization is to create a clean breathing space, free from contaminants. All particles floating in the air will be negatively charged and cling to each other or to objects in the room (like walls) that are positively charged.
If you cook, there is some smoke created, or when you burn candles. These greasy particles will stick to the wall or to surfaces. Cleaning them up regularly might help. You can also try another product from EcoQuest called EcoH which is based on enzymes and cut through that grime easily. That might take the black stuff off the walls.
Dutch
Mar 01, 2009 | Ecoquest Flair Air Purifier
Only one plate inside, it's glass edges are broken or deteriorate
I haven't seen an older Flair that I know of. There will be as many slots for plates as are required. The filter is definitely washable. Use an enzyme cleaner and rinse with hot water. The fan motor should be oiled every month or two. It should cost less than $100 to get it running in top shape.
Feb 08, 2009 | Ecoquest Flair Air Purifier
Flair living air purificaion system
here are parts for your air purifier, including the motor and other parts you may need in the future.
AirPurifierRepair.
- just click the link
hope that helps, good luck
Jul 31, 2008 | Ecoquest Flair Air Purifier
Fan trouble with Flair
remove the retaining screw from the bottom of the unit and slide the insides out the back. use WD40 with the plastic extension tube, spray into the motor armature/stator and turn with your hand until it is free spinning then reassemble and turn on.
this is an ongoing problem with my unit because the air and all contaminents are pulled directly to the fan.
Apr 04, 2008 | Ecoquest Flair Air Purifier
Ecoquest Flair Air Purifier Logo
119 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
