Question about Denon AVR-2106 Receiver
No sound new system,every thing hooked corectly.only one spaeker lead is working
    Scholar:
  • 67 Answers
Try Referring to Owners manual about the Intialization procedure. This will reset unit to factory defaults. Then try setting up like you bought it new. Procedure enatails pressing two buttons when turning on main power switch. . All leds will light up to let you know Unit has been initialized. Denon provides free manual downloads if you don't have manual.
Posted on Jan 16, 2008
6ya staff
SOURCE:
Velodyne dps 10 rca hums but wired is fine
The issue a floating ground that causes the hum you are talking about. What are you connecting it to that causes the hum?
Jan 07, 2014 | Velodyne DPS-10 Subwoofer
Hi iam using dell vastro A860 laptop just recently face one major problem laptop internol spaeker sound not working when i use headphone sound working good what hapend the sound is notworking iternel...
Very possibly you muted the sound. Check the little speaker icon in the system tray. When you click it you should see if it is muted or not. Muting the speaker does not mute the headphones, as a general rule.
Oct 21, 2011 | Dell Vostro A860 Notebook
The system "pops" regularly when TV is playing.
The first thing to check is, all your connections to where you have it hooked up to, also check that the cable is in it's proper location, meaning your out put is leading to you other receiver in put, visa versa for the main receiver leading to the secondary receiver. If all else fails, leads to one thing, their is a possible short within One of the voice coils embedded into the speaker base. Which means, time for new speakers or check for warrantys or guarantees on the product. You could also check the companies website if you can't find a receipt. This is going off personal and past experience. All the best luck!
Jul 08, 2011 | Panasonic Home Theater System System
I need the diagram to be sure to hook it it corectly thanks
not sure what you are hooking up...if you are putting on new spark plug wires...locate the distributor...usually marked #1 and goes in clockwise circle...firing order for the V8 is 18436572...hope that helps...usually changing one wire at a time is best...to not confuse the firing order...
Dec 09, 2010 | 1983 Chevrolet C1500
Speedo not working corectly
This is an electronic speedo, could be several things but probably 1st and easiest thing to try is repalceing the vehicle speed sensor(vss). Also need to know if check engine light is on, and if any other electrical items are malfunctioning.
May 31, 2009 | 1997 Toyota RAV4
Too much gas in carb
Check the timming.And make sure the HT leads ar fitted corectly.
May 30, 2009 | 1984 Chevrolet Chevy
Adding Spaekers
If it's an original 321 system (series 1) then it has an audio output on the back. (via RCA jacks) You would still need an amp or receiver to connect the speakers to.. (unless they're powered speakers)
If it's a 321 series II or 321 series III- it does not have an audio output.
If the system has a DVD tray right in the middle of the media center, then it's a series 1.
Otherwise, you'd have to get a 1/8 splitter to come from your Mac's headphone output. (still- you will need an amp/receiver or powered speakers to have both 'rooms' playing the same thing from your computer)
May 29, 2009 | Bose 3 2 1 GSX System
Outside bose speakers keep turning off after a few seconds
It sounds like the speakers are either peaking and shutting down or they are dodgy. Check the volume going into the speakers and turn it down see if that works, otherwise take the speakers back. It might be worth trying a different set of speakers as well
May 24, 2009 | Bose Lifestyle V30 Home Theater System -...
Hooking samsung htz310 into insignia 52 inch flat screen
From what i learnt you learnt to connect tv to system with hdmi and a  optical lead..
Jan 20, 2009 | Samsung HT-Z310T Theater System
Denon AVR-2106 Receiver Logo
132 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
