Question about Compaq Armada 1700 Notebook
Does not power up
Do i need battery to power up i plug it in and the two lites on the bottom under the touch pad flash and that is all it is a armada 1700
  • Jonathan Hypke
    Jonathan Hypke Jan 16, 2008
    the laptop does not have a battery
    Champion:
  • 207 Answers
Its alright..usually, the total charging time of Laptops is about an hour or two. What is unique in laptops is becuase it has automatic cut-off charging feature that your laptop has the ability to turn off the charger when its already battery full no matter how many hours you've using it.
just enjoy what your doing.ok? =)
Posted on Jan 16, 2008
6ya staff
SOURCE:
How can i bypass my forgot admin password on my compaq armada e500
With the older Compaq Armada E500 Notebook PC, I believe;
1) Remove the CMOS battery.
2) Leave it out for 30 minutes.
3) Press the Power On button, and hold it for a count of 10 seconds. Let go of the Power On button.
Press it again. If the Power On light comes on, hold the Power On button in, until the light goes out. Keep pressing, and holding the Power On button in, until the Power On LED light does Not come on anymore.
Reinstall the CMOS battery. WAIT 1 minute, turn the laptop on.
If this doesn't do it, there is a capacitor inside the laptop keeping residual power. There may be two copper pads that are briefly touched across, to dissipate this residual power.
Perform the removal of the CMOS battery first. If this doesn't work I'll try to find info on the copper pads. (They are usually under the Wireless Card, and a small piece of Mylar plastic sheet)
Post back in a Comment as to your findings.
Regards,
joecoolvette
Jan 22, 2012 | Compaq Computers & Internet
Orange light for a second then nothing
Possibly a bad charger? Try getting a new one.
Jan 27, 2010 | Nintendo DS Lite Console
Potentially dead Nintendo DS lite LCD screen. (bottom)
Hey, I can help you.
Yes, the Bottom LCD is dead. You will have to exchange it.
Below I have two links you should follow through. One to purchase a bottom LCD for a very cheap price and the other will show you how to replace the bottom LCD.
REMEMBER.. To place a plastic pad under the bottom lcd so it doesn't ground out the board. Forgetting to do this could potentially blow a fuse and you will have to replace those!!
1.) http://www.amazon.com/dp/B000RWXCE2?tag=wit08-20&camp=14573&creative=327641&linkCode=as1&creativeASIN=B000RWXCE2&adid=0JJ799NSS5VV0XTY8DYK&
2.) http://www.instructables.com/id/S3ZZJPKFA0CVIFO/
May 27, 2009 | Nintendo DS Lite
NINTENDO DS LITE WON'T CHARGE OR POWER ON
Each time you charge your battery, the charge capacity is decreased. After a large amount of charges, the capacity is decreased to an amount only enough to turn on a/the screen(s) for a second. Try getting a new battery.
Mar 02, 2009 | Nintendo DS Console
Compaq armada 500 (touch pad not working)
look at the ribbon/connector again, make sure it's not broken.
Sounds like a broken ribbon or bad connector.
May 23, 2008 | Compaq Armada E500 Notebook
NIntedno DS lite bottom screen
IMPORTANT: it is not a grave or expensive problem but to solve this problem you need to dissasemble the intendo DS lite, so you must get some guidance like youtube videos on how to dissasemble the NDS Lite or other webpages with info on dissasembling the unit.
You have to carefully open the console, then check for unplugged flex cables and reinstall cables in the connectors to be sure. Then put the console together without screws to retest the unit and see if the screen is working now.
If not then you need a replacement bottom screen and depending on your abilities to retire the touch pad without cracking it you might or might not need a touch pad.
Take out the battery and charger to avoid short circuits while working.
Good Luck...
Apr 07, 2008 | Nintendo DS Lite Console
The toch screen isnt working
You also need to buy a replacement touch pad.
You have to carefully open the console, unplug and take out the bottom screen with the sticked touch pad, then carefully with a thin blade or metal you have to take out the glued touchpad from the screen without cracking or scratching the screen, to be able to install the replacement touchpad over the screen.
First take out the battery and charger to avoid short circuits.
Good Luck...
No boot
Sounds like the motherboard is getting power to the lights but not to the rest of the computer. try to drain all the power out of the laptop by unplugging it and holding the power button for 30 seconds. Then plug it back in and try again if this does not fix it your motherboard is probably shot and would need replaced.
Jan 21, 2008 | Compaq Armada 1700 Notebook
Armada 1700 laptop
remove the battery and power from the A/C and then plug in the battery and a/c cord
Laptop
Most laptops will run without the batteries, its only a few that won't however I do not know for your specific laptop. So its a possibility. Although, the two lights mean that the unit has power so its likely that it doesn't need a battery and the laptop won't boot.
Do you know what the green flashing lights represent?
Jan 16, 2008 | Compaq Armada 1700 Notebook
Compaq Armada 1700 Notebook Logo
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
