Question about Vulcan Convection Oven - VC44EC-208-1
Why won't my oven ignite? Vulcan model GC04c
I have recently converted vulcan gco4c from natural over to propane gas. I have it all hooked back up and when I power it up, the blower starts up, the digital interface comes on and shows the temperature that I set it to. The valve that I regulator that I replaced(natural to propane) clicks, then there is a box that controls the electric ignition on the back that clicks. Soon afterwords the digital screen shows a Er-05 and just beeps. How do I know if the gas is being sent into the combustion chamber? How do I know if the ingiter is actually sparking? What could be my problem? Does anyone know where to download an operators manual? Thanks in advance for any help.
  • thaddeus333 Jan 17, 2008
    So now the service gas valve, the one on the front of the unit that I turn to allow gas to enter the oven is now leaking. It is a simple brass on brass turn valve. I took it apart and could not find any damage, but everytime I open the ball valve on my lead in hose, the valve leaks. Any suggestions would be great.
  • 640 Answers
I can get you the error code but dont have my manual at the time.a couple things to check.do you here the clicking sound of the ignitor that ignites the gas?when you installed the regulator are you sure its on right?you should see an arrow on the regulator body and it should be pointing to the oven.also you need 10 inches of water colum (gas pressure)with a propane system where as natural you need less,regardless ill be in touch.
Posted on Jan 17, 2008
6ya staff
SOURCE:
Would like to change my Vulcan from natural gas to propane gas
most likely they do , but many do not have a conversion kit anymore .
Sep 11, 2015 | Vulcan Ovens
I have a Sears Kenmore Elite 790 hooked up to propane .. is it ok to have it hooked up to propane or is this over for natural gas only?
Kenmore Gas ranges can be used with Natural gas or Lp. They come from the factory set up for Natural gas so if you want to use Lp it needs to be converted by you or your gas company. There are several adjustments that have to be made and some ranges require orifices to be changed. Your installation manual tells how to convert it but if you're not sure about doing it you would be better off the call the gas man.
Aug 28, 2011 | Ovens
Need to know how to convert from natural gas to propane. vulcan oven,.. model 60XL77R. thanks!
I am looking to change from propane to gas. Willing to swap parts
Mar 16, 2011 | Ovens
Vulcan convection oven model SG4d-1 will not ignite burners
Gas does not ignite. No spark. No Ignition light is not ON.
1. Shorted electrode on igniter/flame sense.
2. Igniter cable (high voltage) OPEN.
3. Heat relay malfunction.
4. Centrifugal switch in blower motor inoperative.
5. Transformer inoperative.
6. High limit thermostat open.
7. Interconnecting wiring malfunction.
8. Ignition module malfunction.
Sparks but gas does not ignite.
1. Gas solenoid valve off or inoperative.
2. Manual gas valve closed.
3. Gas supply OFF or insufficient gas pressure.
4. Inerconnecting wiring malfunction.
5. Igniton module malfunction.
Feb 23, 2010 | Vulcan Convection Oven - VC44EC-208-1
Burners work but oven does not
try lighning the pilot.
Mar 13, 2009 | Ovens
CONVERT FROM NATURAL GAS TO PROPANE GAS
Pat, it is very important that all appliances that used natural are guaranteed to be LP Gas approved. Fact is natural gas uses about 1/4 oz. psi where Lp Gas uses 8lbs. to 13psi
This is critical that the person doing the work has experience in converting the two types to prevent fire or property damage. I hope I helped answer your question, let me know if this works out for you. Thanks, Sea Breeze
Feb 01, 2009 | Vulcan SG44D Gas Double Oven
Problem gas cooker
Go on line to westing house.com and look up your model, go to the help page and ask for their assistance, gas is not something to fool around with, I suspect it is the orifice that have not been converted to propane, I had a similar problenm with the stove top burners, and the orifices needed to be changed to (converted ) to run on propane gas.Some times manufactures send the converter orfices but most of the time you have to ask for them if you are running on propane, most stoves are set up for natural gas not propane.Most of the time the store clerks don't ask you if you will be running on propane , you have to tell them and the professional who installs the unit needs to install the orifices. Please be careful! If you installed the stove your self, you need to contact a professional installer to correctly adjust these .
Jan 05, 2009 | Frigidaire FGB24S5A Gas Single Oven
Vulcan space heater lighting instructions
turn the round knob to left "the ignitation" spot, then push down the button to light the pilot.
May 07, 2008 | Ovens
Problem again with the Vulcan GCO4C
i wasnt in on this from the begging but have you changed the safty valve on the burners and what code is er-5 havnt had no experence with vulcan but the regulater dont run the gas the safty valve does and have you checked the probe in the oven at 70 degrees it should be 1200 ohms
Jan 30, 2008 | Vulcan GCO2D Gas Single Oven
VulcN MODEL gc04C CONVECTION OVEN WON;T IGNITE ER-05 CODE
Like an electronic igniter for a gas grill? I believe you can pick up a replacement. Call Lowes or Homedepot. I know i have saw individual igniter's before my friends bought some for my friend and I when we were little to make potato cannons.
Jan 22, 2008 | Vulcan GCO2D Gas Single Oven
Vulcan Convection Oven - VC44EC-208-1 Logo
521 people viewed this question
Top Vulcan Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Dennis Boxerman
Are you a Vulcan Oven Expert? Answer questions, earn points and help others
