Question about Texas Instruments TI-86 Calculator
Switched the TI-86's batteries but im getting a black screen
The batteries had died on the calculator so i just put fresh ones in... Im getting a black screen... Do i need to program it? I didnt switch the back up batteries. Is this maybe why Im getting the black screen. HELP! Thanks!
  • Texas Instru... Master
  • 8,081 Answers
After changing the batteries the calculator is o restored to factory defaults, but the screen contrast may change. The screen may be too light to see anything. Darken it a bit.
Press [2nd] key and release it.
Press and hold [UpArrow] until screen is dark enough.
Hope it helps.
Thank You for using FixYa and for rating the solution.
Posted on Dec 02, 2009
    New Friend:
This totally worked k24674!!!!! THANK YOU!!!! I have a math final tomorrow and you saved me!!!!
xoxoxoxoxo
Posted on Dec 15, 2009
SOURCE:
When i turn it on a black screen pops up and i cant see the problem im putting it how do i take off the black screen
Try adjusting the screen contrast. To lighten the screen, turn the calculator on, press and release the 2nd key, then press and hold the down-arrow key. To darken the screen, use the up-arrow key instead of the down-arrow.
Feb 21, 2011 | Texas Instruments TI-86 Calculator
Hi. I changed the batteries on my TI-86 and when I tried to turn it back on the screen was completely black. Do you know what the issue could be?
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If the screen is completely black, go the other way, using the Down-arrow instead of the Up-arrow.
If this doesn't do it, please reply to this post and we'll go on from there.
Nov 04, 2010 | Texas Instruments TI-86 Calculator
I have TI-89. I didnt use it since 2 years. but now after changing its battery it showing me just black screen with many straight lines. What should i do
Take out one battery. While holding the "On" button, put the battery back in. It may take more than one attempt, but it should start working again. Tell me how it works out, and hope this helps!
Oct 10, 2010 | Texas Instruments TI-86 Calculator
Ti-86 screen turned black after replacing the batteries
Turn the calculator on. Press and release the 2nd key. Press and hold the down-arrow key until the screen lightens. If you go too far, press and release the 2nd key and then press and hold the up-arrow key.
Sep 13, 2010 | Texas Instruments TI-86 Calculator
My ti-86 screen is black is that normal. I have not used it in years, but i put fresh batteries
Hello, First of all no; it is not normal for your screen to be black. How can you enjoy the wonderfulness that is Ti with a dark screen. For the solution; it sounds like your contrast needs to be adjusted. Hold 2nd and down. The screen should lighten. If it reaches about where you can not see the cursor, then press 2nd and up and this will darken it. Hope this helps; Happy Calculating
Aug 27, 2010 | Texas Instruments TI-86 Calculator
My screen is black after putting in new batteries in my TI-86
Adjust the contrast. Turn the calculator on. Press and release the 2nd key. Press and hold the down-arrow key until the screen lightens. If you go too far, repeat the process using the up-arrow key instead of the down-arrow.
Aug 17, 2010 | Texas Instruments TI-86 Calculator
Calculator (TI-86) will not come on.
Make sure batteries are fresh (unspent)
Make sure batteries are inserted correctly, respecting the + - diagram.
To adjust contrast:
1. Press and release [2nd[ key
2. Press and hold [UpArrow] key to darken screen or press and hold [DownArrow] to lighten it. Keep it until contrast is to your liking.
Hope it helps.
Mar 15, 2009 | Texas Instruments TI-86 Calculator
No power up
turn it on and immediately pull out the battery: fixed my TI-85 if not its ded :-(
Feb 01, 2008 | Texas Instruments TI-86 Calculator
Texas Instruments TI-86 Calculator Logo
1,072 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
