I am having this SAME problem with MY Commando. Exchanged the Jawbone with a new one of the smae model. Same thing! Have even purchased a BOSE Bluetooth to replace the Jawbone that I still own, EXACT same condition with both ( all THREE units if you count BOTH Jawbones ). Anybody have any suggestions? I love the phone otherwise, but cannot use a Bloothheadset! VERY ANNOYING ! Any guruh's ( I am not )have a solution?
Don't spend lots of money buying blue tooth headsets Go to your local Walmart and purchase the Emerson Blue Tooth headset it comes with 2 ear loops that are made of a flexible plastic and 6 inner ear buds for a very snugged fit. The ear loops will also fit your LG blue tooth headset. You can also purchase the headset by following this link http://www.walmart.com/ip/Wireless-Gear-Bluetooth-2.0-Headset/15852098
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device. Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
I have a Jawbone and have not experienced those problems. You may have a connection issue with your phone. Maybe the way your blue tooth is set on the phone....power settings?
- turn off
- hold down both receiver buttons as long as the led blinks red
- search with your mobilephone and connect with key 0000
(sorry, my english is not that good, i hope you know what i mean)
Contact Motorola and tell them the situation. They will send you new ear hooks. I've done this twice since they don't have replacement parts available publicaly
ok it took me a while the way u need to do this pairing is easy they just explain it really bad.
in your phone find the add device
press the call button till the purple light comes on
open the FLIP(microphone part AND THE EAR PEICE!!! people for get the ear peice)
press ok and have your phone start searching
once it finds the device press 0000 for the pin
your all set i almost sure this will work!!!
