Monitors
Problem for Monitors
Generic problem for all Monitors
Philips 104E width uncontrollable
By MohanKS on Jan 16, 2008
hi,
my philips 104E (14" color monitor) width is now permanently stretched out and uncontrollable even with horizontal size control button.
Please help me out
Solution #1
posted on Feb 20, 2008
Not Rated)
kishkane
Rank: Wiz
Rating: 76%, 159 votes
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
how do i change the input to hdmi
Answer
i have a tv using a svidiod cable to connect and just got this provview and hooked it u and it did... (More)
Answer
princeton 19 inch LCD blinks and chirps. i need a manual for it ,plus i have anHP pavillion zd7310... (More)
Answer
I have a monitor model fpd1530 from gateway and when I turn on it says safe mode then goes blank
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Monitors:
Top Monitor Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
