Question about Efficient Networks SpeedStream 5260 (120-5260-004) Router
Speedstream 5260 I can't connect to the internet. I noticed that only 3 of the 4 lights light up. The first & the fourth show a steady green light. The second does not light up. The third flashes green & red. What can I do to connect to the internet?
  • 3 Answers
There is a problem with yur dsl connection check for physical setup between the modem and the telephone wall jack
if the problem exists contact your isp
if u r not too sure abt the physical setup pls contact your isp providers and they will help you to run through the steps
Posted on Feb 06, 2008
Slow wireless connection
Please call the service provider and inform this problem.They will help you know how to fix this problem....You can also go to nearest store and fix this....To check the internet speed visit the site Scanmyspeed.com
Jul 18, 2012 | Efficient Networks SpeedStream 5260...
We need to be able to join the wifi network, but no one seems to know the password. How can we find out, or reset the password?
Reset Instructions
CAUTION - this will reset ALL ROUTER SETTINGS. In other words, you will lose the configuration information and will need to reconfigure all of your settings. .
  1. Leave the router on and connected/wired
  2. Turn it over and find the recessed reset button on the bottom.
  3. Press and hold the button until the power light flashes red/green.
  4. Release the button.
  5. Now go through the setup instructions found in the manual.
Your manual can be found here.
Jan 13, 2011 | Efficient Networks SpeedStream 5260...
I installed a Dlink Telephone adaptor between my speedstream 5260 my PC. I think I need to change the MAC address on the speedstream. How do I do that?
Connect one of your computer to the LAN port of the speedstream, access the configuration page of the speedstream (example 192.168.1.254) then under advance tab there a MAC filter there that you change the MAC address.
Mar 15, 2009 | Siemens SpeedStream 5260 ADSL LAN Modem...
My modem is not working, all the light are solid green but is not conecting to the internet.
Click the Edit menu, click Find, then click People.
Select the Internet directory service you want to search at the top, type in the person's name, then click Find Now.
Feb 19, 2009 | Siemens SpeedStream 5260 ADSL LAN Modem...
Speedstream 5260 (5262) //EnterNet300
i m sorry to say that enternet300 1.5c is not available these days in online.
instead of enternet , windows xp has a similar built in interface, its 99% similar to enternet
try configurin your isp using this simple procedure, configuring this interface is pretty easy compared to enternet.
so go ahead and give a try . i m sure u wont regret !
•Go to Start->Control Panel •Then Network & Internet Connections
•Then Network Connections
•Select Create a new Connection
•Click Next
•Select Connect to the Internet then click Next
•Select Set up my connection manually then click Next
•Select Connect using a broadband connection that requires a user name and password then click Next
•Type in your ISP's name then click Next (**See Note Below)
•Enter your user name as provided by your ISP.
for example: You might need to inlude your domain as part of your username. pacbelluser@pacbell.net
•Enter your password, then confirm it
•Select Use this account name
•Select Make this the default Internet connection then click Next
•Select Add a shortcut to this connection to your desktop then click Next
•Hit Connect
i guess this must resolve your issue :)
Jan 30, 2008 | Siemens SpeedStream 5260 ADSL LAN Modem...
Speedstream 4100 modem
can be a deffective modem.. they Bell.ca had replaced mine only 5 times..
Dec 29, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Speedstream 5100
FOR AOL Instructions see the first question in
http://www.smallbusinesscomputing.com/we...
As far as configuring the router try
http://www.dslreports.com/faq/efficient/7_Misc._Questions
or
www.waymark.net/tech_support/DSL/SBC/5260.pdf
or
http://whirlpool.net.au/index.cfm?a=h_view&model_id=112
FROM THE SECOND LINK --
Installation Requirements
To install the 5260 ADSL LAN modem, you will need the following:
• A computer equipped with an Ethernet network interface card (NIC) or
an Ethernet hub
• A DSL-ready telephone line installed at the desired installation site
Package Contents
Your package should contain the items listed below. If anything is missing
or damaged, please contact the dealer from whom the equipment was
purchased.
• 5260 LAN modem unit
• Power supply
• One RJ11 unshielded twisted pair (UTP) cable (for the DSL connection)
• One RJ45 UTP straight-through cable (for direct connection to a PC
with a NIC installed)
• Installation Guide, Safety and Certification booklet, and Release Notes
(if applicable).
Nov 29, 2007 | Efficient Networks SpeedStream 5260...
Belkin Router - Network works for 5 minutes than everything loses internet capability.
hi,
           This issue usally occurs when the router is able to save the data stored or in  other words the Router id not able to AUTHENTICATE,  but as you already got a new router and you have already done the fireware upgradation of the router. we can also upgrade the firmware of your speedstream modem.
plz do these following steps ,( plz disconect the router from the computer and modem completly while doing the steps )
The Efficient 5260 modems that can be upgraded are as follows:
Look on the label on the bottom of your modem. It should read:
SpeedStream 5260 Ethernet ADSL Modem
Part Number: 060-5660-00x (where x=any number)
Revision: any (all revisions seem to work)
If your part number reads anything else, your modem is most likely not upgradable.
For those curious, 5660 models 003 and earlier do NOT support G.Lite ADSL, only DMT. If you are buying a 5260 or 5660 model secondhand, and your DSL ISP uses G.Lite DSL, it would be a good idea to check with the person selling you the DSL modem.
UPDATE: As of 5660 Firmware v2.3.0(2) and later all 5660 including 5260/5660 hybrids support G.Lite ADSL. It pays to use the latest Firmware.
PLZ REPLY IF THIS HELPS, I WILL TRY TO FIND OUT THE RESOLUTION FOR THIS ISSUE
REGARDS.
Gunjan ';';';';';';';
Oct 18, 2007 | Belkin (F5D8231-4) Wireless Router...
Can't get modem to work
speedstream 5260 modems don't have a built-in pppoe in it, so with your win xp OS you just have to make a broadband connection using the new connection wizard by either going to control panel > network connection > new connection wizard or in internet explorer, click on tools menu > internet options > connection tab > click on setup button. follow the wizard and type your username & password on your registered internet account. also make sure you delete your previous broadband connections (if you have set up one before) to avoid conflict with the new connection.
the set up is different if you are using lower versions of windows OS, (like win2000, ME, 98 SE/ FE or 95? ) or Mac 9 you may need to install a pppoe software such as Enternet 300, WinPoet, etc.
Dec 18, 2006 | Siemens SpeedStream 5260 ADSL LAN Modem...
Not working ,just red light
If you have all red lights, this indicates a problem with the router. Please contact your ISP to make sure that your internet connection is working correctly. Did you receive this router from your ISP or did you purchase it directly? Has it worked in the past and just suddenly stopped working? Please provide more details for me to provide you with further options.
Oct 29, 2006 | Efficient Networks SpeedStream 5260...
Efficient Networks SpeedStream 5260 (120-5260-004) Router Logo
486 people viewed this question
Top Efficient Networks Computers & Internet Experts
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
Michael Galve
Michael Galve
Jax Planet
Jax Planet
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
