Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-52D62U HDTV won't tune-in channel 21.
My Sharp LC-52D62U HDTV won't tune-in channel 21. I have cable TV and the coax cable is connected directly to the TV. I've done the channel scan several times but it skips over channel 21. If I tune to it manually all I get is black and white wavy lines and buzz in the audio. The previous smaller LCD TV tuned it in ok. The cable company came and checked the cable at the TV and his testing instrument showed channel 21 was working fine.
My question is: Do you know of any service codes to manually change the channel frequency for channel 21?
My thought is that channel 21 is a little off the tuning frequency to receive the signal properly.
BTW, The TV tunes in all of the other channels including all the QAM local HDTV channels just fine.
  • 1 more comment
  • Anonymous Mar 13, 2014
    how to tune tv
  • Anonymous Mar 14, 2014
    tv will scan and find one channel, used to get 10 to 12 channels, our other toshiba same model works fine
  • Anonymous Mar 20, 2014
    I have an element model # elcfw329 that won't tune in digital channels in the 100's , I have a sanyo tied in to the same cable system that does it just fine ... any fixes?
I finally got Sharp to repair the TV. It was under warenty but they said if the problem wasn't with the TV they were going to charge me for the service call. I told them I wanted a new TV. They sent the tech instead of a new TV. He replaced the turner card and it worked!! Now I get all the channels as well as channel 21.
Posted on Mar 01, 2008
    President:
  • 1,284 Answers
Sounds like the signal is probably too strong. The TV is not the problem.
Posted on Feb 21, 2008
SOURCE:
How do I tune my Sharp tv to channel 3 so the cable will work?
Go to the Tuner setup screen and select cable instead of air. Then put the TV on Channel 3 and connect the cable box to the antenna connector on the TV.
Jul 04, 2014 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
Picture Issue with a Sharp Model LC-52D62U LC-52D62U
You don't say what the issue is so giving a good answer is impossible. There are 3 major circuit boards on the TV. Problems on any of them can affect the picture. Give us an idea of what the issue is and then we can trouble shoot it better.
Mar 22, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
TV only detecting channels 2-13 should be detecting 2-63
Go back to the initial set up procedure for your Sharp TV and do a search for active HD channels. They will be decimal numbers such as 13.1.
Jan 13, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
LC-52D62U
is it connected to anything??
Jan 13, 2014 | Sharp LC-52D62U 52 in. LCD HDTV
We lost local tv from Dish on one of the local channels. We want to use the TV (model LC-46D85U) to view the local channel. How do we get the TV to view in local over the air instead of the satellite. ...
Connect air antenna to RF(coax) input of tv. Go to the menu and look for channel setup.Select antenna and auto scan. When done scanning you should have whatever stations you are able to pickup. Connect Sat reciever to one of the other input on the tv. Then go to INPUT or SOURCE on remote and select tv for local and what ever input you sat box is connected to for dish.
Mar 07, 2011 | Sharp Televison & Video
I BROUGHT A USED SHARP AQUOS TV I CAN'T GET IT TO SEE MY CABLE KEEP SAYING FAIL TO RECEVE BROADCAST
How are you connecting it to cable tv?
If you are using a coaxial cable to a cable box you have to turn to channel 3.0 with a Sharp remote by pressing 3.0 enter the dot (.) is down by the 0. There is a way around this if you don't have a Sharp remote. You can go into the menu and complete a channel scan. If the model you own is the one pictured then you should have the coax cable connected where it says analog if you are connecting to a cable box this way.
If you are using composite, component, or hdmi cables you press the input button on the television and pick the right input. It is recommended that you do not use the coax cable anyway unless you do not have a cable box. There is an input button on the television and on the remote.
Dec 15, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Varous tv channels do not have sound. It is NOT a
TO: rdh041: I don't have the solution to you problem, but we have the exact same problem with our Sharp AQUOS 20" LC tv. Different model than yours, but same age and same perplexing issue. Several channels suddenly have no sound. If you've found a solution, would you please post it? I'll do the same. Thanks.
Jul 15, 2010 | Sharp Aquos LC-20B6U/LC-20B6E 20 in....
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My (sharp aquos lc 52d62u) tv fell to the ground. Image of broken glass and colored lines appear
Unfortunately the panel is cracked internally can't can't be repaired the whole panel has to be replaced. most times the panel will cost as much as you paid for the set. My son cracked ours when it was only 3 weeks old it doesn't take much force to ruin one.
Rustym62
http://www.the-tv-dude.typepad.com
Apr 26, 2009 | Sharp LC-52D62U 52 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
828 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
