Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Noises Last winter we lost power for days, ever since, our two years old refrig started making noises often, we are not sure where exactly, but it does sound like it has something to do with the water going into the ice makers. I understand it's normal for some degrees of noise when the water is filling up, but this happens very often and honestly, I don't remember the refrig. used to make so much sound and often throughout the day. Is it normal? or this is something that I can fix it myself? Please help!
  • shishroo Jan 19, 2008
    How do you manually defrost the refrig? by unplugging it? or just take everything out and turn it into the lowest? Thanks alot!
    Master:
  • 619 Answers
Hi , small fan motor inside the infeller was touch to the build up of ice., it need to manual defrost to lesser the ice inside .
Posted on Jan 18, 2008
Hi! I've had a 2004 VW Jetta since last November (had 39K on it). It has worked perfectly throughout the winter and spring. Not that it's summer, I've had a small intermittent problem: after...
POSSIBILITY HERE IS THAT THE FUEL PUMP IS ACTING UP. THE REASON IS BECAUSE WITH THE WARMER TEMPERATURES THE PUMP HAS TO WORK MORE AND THIS WILL CAUSE IT TO MALFUNCTION
Jul 27, 2011 | 1999 Volkswagen Jetta
In the winter when i would start my car it idled weird.. a couple weeks later it was hard to get my car started... when i start my car i hear like water trickling noises.. i was driving down the road and...
cold starts and thick oil make starting hard in winter, use 5 w 30 w for most applications of winter oil ,, the trickling noises you may hear a re the manifold or its cover warming up and making crackling noises , be sure and use antifreeze in your radiator too!!!
Jun 22, 2011 | 2002 Nissan Sentra
My three year old Karcher power washer has suddenly started behaving as if it has lost its power. There is also an intermittent motor noise when I release the trigger. When I press the trigger again the...
This sounds like it had water left in it and it froze over the winter. The motot turning on and off signals a water leak on the output side of the pump. You may have a cracked pump housing. Locate the pump and make sure nothing is leaking in that area when under pressure. looh for fine hairline cracks.
Apr 01, 2011 | Karcher Garden
I have a ge profile side-by-side model tfhw22r refrig/freezer that has started to make a rattling noise (possible from the rear of the freezer side) that may more accurately be described as the sound...
Sounds like the compressor has a broken spring inside. The only fix is to replace the compressor. But before calling a service man, disconnect the power from the unit and remove the cover on the back covering the compressor. Look for any loose parts at the compressor. Make sure nothing is touching the compressor causing the noise. Make sure the pan that holds water during the defrost cycle is not loose and rattling. If you feel safe doing so, plug it in and see exactly where the noise if coming from. If it has never been cleaned then clean all the coils and all around the compressor with a vacuum cleaner but make sure it is not plugged in when doing this and use care not to damage any parts. They make a special tool that goes on your vacuum wand to reach inside the coils to remove accumulated dust. If you find no loose parts and determine that the noise is coming from the compressor all is not lost. The compressor can be replaced if the unit is otherwise in good condition. If it is over 15 years old, I would consider purchasing a new unit and not repairing this one. I hope I have been helpful.
Oct 30, 2010 | Refrigerators
My Samsung 60 inch DLP TV turns its self off several times an hour. Eventually is stays on. What's the problem?
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.Have a bless one!
Apr 20, 2010 | Samsung Televison & Video
Temp. is on automatic settings for "Red Wine" but fluctuate between 51-59 degrees, not to mention makes all sorts of noise (common refrig. noises) is this normal? Haier 35 bottle wine refrigerator
temps will fluctuate. depending on door openings and defrost cycles.no abnormal noises heard on the ones ive worked on but appliances tend to be noisier then they were. if less than a year old have an authiorized servicer go out and look at.
Sep 16, 2009 | Haier Refrigerators
Avenger chain problem
first thing is check the alignment of the rear sprocket to the front sprocket and make sure it is dead straight,when you change wheels you have to make sure that the spacings are ...exactly...right or you will get alignment problems,the chain will wear badly and the sprockets will not last long either,if the chain is three years old "replace it"with agood quality one and if the sprocket teeth look worn replcae them to or they will eat your new chain ..fast..hope this helps
Jun 07, 2009 | 2005 Bajaj Bajaj Avenger
Ice Maker Making Noise
sounds like your icemaker is jammed.
first ofall just feel around the icemaker and see if you can find a peice of ice jamming it that you can remove. if that doesnt work heat it up with a blow dryer until any ice that is there will melt away and it will free up..
there is one other possibility: the stripper could be jammed against the side of the icemaker in which case you'll have to remove the icemaker from the refrig and unjam it..
hope that helps and good luck
Dec 15, 2007 | Jenn-Air JBL2086HES Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
81 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
