Question about LG LH-D6230 System
Lg LH-D6230. How to hook up? PLEASE HELP! NO INSTRUCTION MANUAL!!
Can anyone help me to figure out how to set my DVD player up to watch and listen to normal free to view TV! with surround sound? I can play DVD's with surround sound, but not tv! I have no instruction book! PLEASE HELP!...
  • bill813 Feb 07, 2008
    tv-insignia 42"plasma & 5.1 insignia dvd with suround sound how to hook up, have wires in place but cannot get sound through speakers.
Je kan met 2 tulp aansluitingen via de dvd speler audio out naar je tv gaan en dan de instelling aux van de dvd speler gebruiken zo kan je surround tv kijken
Posted on Aug 18, 2008
Tip
LG LH-D6235 Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
____________________________________________________________________
Download LG LH-D6235 Home Cinema System Manual
on Jul 14, 2010 | LG LH-D6230 System
Please anyone HELP!!!!!!!!!! How on earth do you set up the radio because i dont have the manual and the the correct remote....im using a universal remote
Here's the link for the manual. Page 27 describes how to do it with the front panel controls.
http://eic.lgservice.com/gcsc/dwn/main
You'll get a pop up saying you need to install an Active X Add On which is fine.
Apr 13, 2011 | LG LH-D6230 System
LG DVD player LH-D6230 - displays "dvd error" soon
Eprom corruption. Replace eprom, and edit in mode service.
Jan 07, 2011 | LG Audio Players & Recorders
No Audio from Input
My 5.1 channel became 2.1 channel. What is going on? It play normally last few days. When i check in SETUP menu, surprised that audio setting change to 2.1 channel. No matter how i reset it , off power, push the microswitch on the PCB board, still cannot turn it back to normal. Anybody can help.....from malaysian
Jun 20, 2008 | LG LH-D6230 System
Audio playback
1.bad rca jacks
2.could be connected to wrong audio lead rca jack
3.the settings in dvd player donot match the receivers example- dts or ntfs
4.make sure its regioned to your player some audio isnt on the disks
5.pc's usually have new cd formats that came out
cd's and dvd's for some reason in this age isnt being able to play fully in older equipment do to the change in cd/dvd formats which makes you go out and buy new equipment it happened to me not just 2 weeks ago bought a new dvd and found out it wouldnt play in my year old dvd deck had to go out and buy new dvd deck then disk and all my others played fine
May 11, 2008 | LG LH-D6230 System
Resetting the progressive scan mode on an LG lh-d2645 home theatre system
the above is correct but you need to have the dvd player on with no disc in so "no disk" is shown on the front display. then hold down the stop button for 5 secs to reset the display mode back.
Jan 20, 2008 | LG LH-D6230 System
LG LH-D6230 DVD
I had a similar problem coming from South Africa to Australia and had to change the regional code setting.
Change to multizone format:
1)Ensure no disk in unit
2)Unplug unit from AC supply
3)Plug unit back into ac supply
4)Use remote control for the following commands:
5)Press the power key, the unit will come on
6)Wait until no disk appears on the display
7)Press sequentially the keys: PAUSE;3;1;4;1;5;9
8) "Code" will appear on the display
9)Press 0 (multizone)
10 Press sequentially the keys: PAUSE,POWER
11)The unit will turn off(standby mode), leaving the new regional code programmed. If you do not succeed at the first attempt disconnect the unit and repeat the above steps (1 to 10)
Hop this helps
Susan
Jan 12, 2008 | LG LH-D6230 System
IS POSSIBLE TO UPLOAD DIVX PROGRAM (PATCH) ON IT ??
Try this:
http://www.videohelp.com/dvdhacks?dvdplayer=D6230&hits=50&Search=Search
Apr 18, 2007 | LG LH-D6230 System
LG LH-D6230
The life of LG optical pick-up is Aprox.1000hours if it is more then 1000 hours used then just replace optical pick-up.
Feb 07, 2007 | LG LH-D6230 System
LG LH-D6230 System Logo
917 people viewed this question
Top LG Audio Players & Recorders Experts
PNiss
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
