Question about Lexmark X4270 All-In-One InkJet Printer
Fax i have a fax printer scanner copy machine can i use my same phone number. to receive and send faxes
  • Soulvisitor
    Soulvisitor May 11, 2010
    Yes you can is that all you wanted to know?
I need simple instructions to operate the receiving and sending of fax information on this lexmark 4270 fax machine .
Posted on Jan 16, 2008
I want to know how i can use my copy machine to a fax so i can use it for incoming or outgoing?
Install software
Make sure all cables plugged: phone cable, USB cable to computer
Send fax from computer:
- print your document to printer HP .... FAX
Send "traditional" fax:
- put your document into scanner input
- type phone number on HP Officejet keyboard
- push button "Send"
If your HP Officejet if connected to phone line, it reseiving faxes automatically.
Hope this helps
Nov 12, 2010 | HP Officejet 4215v All-in-One Printer
Cannot send faxes
check whether you have loaded the scanner software .
Sep 03, 2008 | HP Officejet 4215v All-in-One Printer
I have an all in one and I can print, scan, and
On the printer press setup-->choose tools option-->under tools-->choose print a fax test page.
Find out how is the printer connected with the fax line.
Note:- Line 1 at the back of the printer should be connected directly to the wall jack of phone line.
Now Follow the instrcution below.
  1. Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
  2. When your fax is received by the HP Test Fax Service, They will generate a return fax to you within five minutes confirming that they have received your fax. This verifies that you can both send and receive a fax with your fax machine.
If you do not receive a return fax within 5-7 minutes, there may be a problem with the setup of your fax machine. Note:-The most common cause of failure is that the fax number set in the Fax Header on the machine does not match the number of the phone line connected to the fax. Also, ensure that the fax header contains the full 10-digit telephone number of the fax machine, including the area code.
May 10, 2010 | HP Officejet 4215v All-in-One Printer
Able to send faxes but unable to receive.
you need to check how the fax machine is setup for receiving faxes. i recommend you try it first without the answering machine, to see if it works. if it doesnt, then it has to do with the auto answer or the number of rings not set right, if it does work, it could be that you need to set it to check for fax while the answering machine is answering, check the manual under answering faxes.
thanks adi
Dec 10, 2009 | Epson WorkForce 600 All-In-One InkJet...
Brand new fax when we send a fax it is received at the other end fuzzy or blurry. Tried a different phone line and still the same. Cleaned glass on scanner
Slight possibility that your sending in Photo Mode, most likely the machine was damaged during shipping and the CCD unit or scanner is out of alignment. Just make a copy....if it comes out blurry then it is the scanner. I would return it for another machine. If the copy comes out nice and clear then there is nothing wrong with the scanner.
Oct 22, 2009 | Brother IntelliFax-4100e Fax
I CAN`T SEND A FAX
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
I cannot receive the faxes. everything else works
It could be a number of things. Could be a phone line issue.
I have seen this with alot of HP style fax machines. It may be to low end to receive from some of the higher end fax machines.
Apr 07, 2009 | HP Office Equipment & Supplies
I get "No Answer" when sending and receiving a fax
Check to make sure the company phone is not setup in the fax machine. If it is, it will need your number to receive. Not all fax machines have this type setup but its worth checking.
I'd go though the complete setup at your number.
Hope this helps. Bud
Jan 08, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
Dec 03, 2007 | Samsung CLX 3160fn All-In-One Printer
Lexmark X4270 All-In-One InkJet Printer Logo
142 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
