Dell Inkjet 720 Printer Logo
Anonymous Posted on Dec 01, 2009
My color cartridge indicates full - but today the colors print very faint like it's run out of ink.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 02, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
91
Points
I wiped the bottom of the cartridge with a wet papaer towel; problem fixed!
mukhtar21 shaikh
Level 3:
President:
  • Dell Master 2,022 Answers
mukhtar21 shaikh
Dell Master
Level 3:
President:
Answers
2022
Questions
Helped
668888
Points
5817
1st you just try with the printing in best mode. still the quality is not up to the mark then try with cleaning. otherwise replace the catridge.
2answers
Color printing
You risk you ruined the cartridge with alcool.
2helpful
Color ink not printing, I have replaced the color ink, I have run all "cleaning" programs etc. When I print a page with some color or colors are a very faint gray. Any help ? No codes, flashing lights etc,...
It sounds like you have a severly clogged print head. The nozzles are likely gummed up and need to be cleaned. To do this, you need to inserta new set of OEM cartridges. Run the deep cleaning utiliity a half dozen times and then the alignment utility. This should clear the problem.
You have most likely been using aftermarket/reloaded cartridges with inks that do not meet the manufacturer's specifications. I would take them back to the vendor and ask for either a refund of replacements. If you are going to continue to use these cartridges, I would take out the OEM cartridges, reseal the two openings on the cartridge ( use electrician's tape) so that they can be used to clear the nozzles should they again become clogged with aftermarket ink.
Let me know if this solves your problem.
The black ink print is very very faint
Indicates that the printer is using only color ink to create a black color. Check printer settings to see if you can set it to use only black cartridge. Also try printing with only the black cartridge inside if the printer permits, this way you can be sure if the black print head is faulty.
7helpful
3answers
HP J4500 color cartridge error
Take the cartridge out and clean the contacts off with something (ie: pencil eraser, your thumb...) That worked for me! I couldn't find a solution anywhere even after chatting with online tech support from HP. Quick and painless! I hope this helps...
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
2answers
Can't print when there's only black ink
Mostly it connot print w/out color ink if when printer message empty / sometimes the printer no message while ink was empty still black can print. it depends to the chip .
1helpful
RX500 EPSOM STYLUS PHOTO PRINTER Won't Print
I used some less expensive generic ink cartridges on my RX500 and had a similar experience with the black. If you're already using the Epson brand, done the head cleaning, realignment and nozzel checks, I'm not much help. Try Epson's support at their web site.
2answers
No color printing with lexmark x4270
How may times did you use the printer to print befor this happened? If you used it a lot then you may need to buy more ink. My printer showed full ink and it turned out that they were empty.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
