Question about Microsoft Wireless Optical Notebook Mouse 4000
MS Wireless notebook mouse 4000
My comp. is not reading the USB reciever to my mouse. It's either that, or the reviever and mouse are not synced themselves, but I don't think it's that because I've hit the connnect button on both devices several times. It was working a few days ago, then I went traveling with it and it no longer works so I'm wondering if that's part of the problem. There is no visible damage on either device, so I'm confused. Thanks in advance.
  • 2 more comments
  • Yamirami Feb 07, 2008
    my microsoft notebook receiver, model 1024 is not working. The wireless mouse is connected and lit, but the receiver's light is not turning on. As a result, I can't use the mouse.Any ideas on how to resolve it?
  • BGonz Mar 02, 2008
    light on usb reciever is lit and mouse is light all other products on the hub work. even if I connect to computer all lights but no interaction with mouse
  • Mszanetti Apr 05, 2008
    Hi ... I had the same problem ... Suddenly the notebook was not recognizing the Wireless Receiver ... changing USB ports was of little help ... then I opened the receiver and I remade all the soldering on the botton of the PCB ... It seems to be a robust solution ...
  • richardz1966 Apr 14, 2009
    I have a Microsoft receiver model 1024, the light sous not come on when plugged into a working USB. I heard you can disassemble the receiver and check the connections. I cannot find any screws that keep it together, does someone know how to open th case to look inside the reciever?
Has this mouse for 3 years and the green light stop working on the receiver. I pryed apart the receiver and soldered the main outside anchor solder joints on the USB plug and it started working! I figured I had nothing to lose. This one will be a good backup mouse as I already ordered a new one.... (Someone else mentioned this as a solution in this thread and it was a GREAT tip!)
Posted on Jul 21, 2009
I have a Microsoft Wireless Notebook Optical Mouse 4000.
I have tried: 1) new batteries in the mouse; 2) re-synching the mouse & USB plug in device; and 3) installing (what I think was the software for this mouse) - all to no avail.
The light does not come on the USB plug in no matter which USB port I use and the error message reads "USB device not recognized".
download.com did not have a download for this device to try to re-load it.
Any help or suggestions?
Patrick
Posted on Oct 08, 2008
I have the same problem, my receiver 1024 hit the floor and I loose rage connection with the mouse, I opened found a little transistor loose, I stick it back but does not work. I guest it is a sensitive transistor broken. don't let the receiver get hit.
Posted on Apr 26, 2008
I have already broken two of them. It seems that the receiver is very sensitive to hits. Probably a PCB issue. I disassembled the receiver and discovered that if I bend it a little it starts working but if I leave it stops.
Posted on Mar 01, 2008
Mouse not working usb plug extremely hot
the USB receiver for your mouse is defective, DO NOT USE IT it could damage the USB port of the notebook replace the wireless mouse
Dec 31, 2010 | Microsoft Wireless Optical Notebook Mouse...
How do I connect the mouse to the notebook receiver?
this is usually pretty simple. Just connect the usb device to the notebook. Then it should say driver installed ok or something to that affect.
if you have already done this and its not working did you try to sync the mouse with the reciever. to do this you have to connect the usb to the notebook. then hit the button on top of the reciever (the thing that connects to the notebook.) then hit the button on the bottom of the mouse. then click the left mouse button and it should work. it should be noted that you have to do this if you replace the batteries as well. thanks
Steven.
Apr 14, 2010 | Microsoft Wireless Optical Mouse
Is it possible to install a wireless mouse without the usb?
No its not posible to install a wireless mouse with out the usb reciever, these usb reciever is attached to the cpu for your wireless mouse to work and be recognized by the system, not unless you can get a replacement that will work with your mouse
hope this help
Feb 03, 2010 | Microsoft Wireless Notebook Laser Mouse...
I bought a mini wireless optical mouse last year at christmas. The batteries went kaput so I put new ones in finally. For the life of me, I cannot find the instructions on how to sync it. I have tried...
unplug the usb reciever and plug it into another usb plug. then once it is reconized . press and hold the reviever button down for 5 sec. then press the button on the mouse that should make it resync
Oct 12, 2009 | Computers & Internet
MS wireless notebook optical mouse 4000
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 20, 2009 | Computers & Internet
Usb Trouble
The USB ports all share a single power source. It may be that the Ipod being added overloads the connections.
You might want to consider purchasing a USB hub, but make sure you get one with a Power Adapter to boost the current to your devices.
Oct 01, 2008 | Microsoft Wireless Laser Desktop 4000...
MS Optical Mouse 4000 problem; computer mouse pad no longer functional
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Aug 08, 2008 | Microsoft Wireless Optical Notebook Mouse...
Microsoft wireless notebook mouse model 1024 will not function.
I called microsoft and they could not fix the problem, stated it was a faulty device and are sending me a new one.
Oct 21, 2007 | Microsoft Wireless Optical Notebook Mouse...
MS wireless notebook 4000 mouse functions
Check your products documentation. Anyway this buttons can be programmed using the Provided Software included in the CD. Hope this helps.
Sep 19, 2007 | Microsoft Wireless Optical Notebook Mouse...
Microsoft Wireless Optical Notebook Mouse 4000 Logo
1,943 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
