Question about Maytag Performa PAV2200
Top load washer
Washer fills up then just hums. No motion at all. Ideas?
  • rstein Feb 17, 2008
    Same problem. If I keep turning the dial I can "force it" into a cycle but then I have to do it all over again. I cleaned all the water filters and it fills rapidly. It is only a year old!
  • Anonymous Feb 24, 2008
    I have an amana top load washer that wont drain or spin it just hums and then blows a fuse.
Sounds like it may be the clutch.
Posted on Feb 01, 2008
Model WTW4800XQ Whirlpool top load washer will not fill. Only hums when on button is pushed. what is the problem?
Does it do it on hot and cold water. Check the water filters where the hose screws on to the washer.
Oct 06, 2014 | Whirlpool WTW4800XQ Top Load Washer...
Cabrio top loader that hums initially when a load starts. i beleve this is during the water in cycle time but not sure. no error codes displayed. Washer works fine otherwise. any ideas???
Yes that sounds right a hum would be at start of cycle if water flow into was restricted in some manner and washer wasnt filling. What your is the hum the water valve makes when is calling for water yet no water from hoses coming to it.
The things to check are for blocked filter screens inside of ends of water valve on back where hoses attach to.
If you have :AQUAFLOW" brand hoses the internal stopper is hose is bad and hose should be replaced using standard hoses
Also for water coming from house pluming where hoses connect to at wall/faucet/spigot
Aug 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The washer will fill and drain, but wont agitate or spin. The motor hums, and the belt isn't broken. Any ideas? Thanks in advance.
Hello,the most common problem is that the lid switch has gone bad and other case it may be the timer or capacitors are faulty.
Thanks
Jun 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
Maytag Atlantis Washer, model MDG6200AWW
I just hooked up my washer and after filling it the motor hummed and smelt like it was starting to burn! Is this a fixable problem?
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
GE Front Loader Washer
Door latch is sending false signal to control board,first replace the door latch.
May 26, 2008 | GE WSXH208A Front Load Washer
Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
May 26, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washer ax6245wv0 roper washer
  Sounds like something in pump.  This is causing motor to hum and not turn.  Motor is going off on thermal overload.  This is why the humming stops.  It may be possible for you to tilt washer back and access pump.  Remove clip on bottom and top and pull pump off motor.  Try and turn pump.  Remove hoses and see if you can see obstruction.
Oct 14, 2007 | Roper RAS8445KQ Top Load Washer
Sound after washer fills up
It sound like you may have a bad capacitor. Just like a standing fan the motor uses a capacitor to boost the current to the starting coil to get the motor in motion. This causes the motor to hum and not spin. Hope this helped. Rudy
Sep 04, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
21 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
