Question about LG WM-2277HW Front Load Washer
LG front washer WM1814CW error OE
I check the drain hose but it is not block . what do I do ??
  • Anonymous Mar 15, 2014
    lg wm1814cw washer
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 16, 2008
Error message oe. and will not spin.
Actually, that is not oe, it is DE, which stands for Drain Error. Check the filter behind the access door on the lower left front of the washer. You should be able to drain the water out using the small hose there first before opening the filter. If there is nothing in the filter, you will have to replace the drain pump motor.
Feb 12, 2011 | LG WM1814CW Front Load Washer
Washing machine flashing oe
OE = Drain Error • Not fully drained within 10 minutes.
Check and clean the pump filter. The access panel is located on the front, bottom left of the machine. Place a towel under the front of the pump filter access panel opening before opening to catch any water that may flow out.
Check drain hose on the back of the machine for any kinks or blockage.
Dec 18, 2010 | LG WM1814CW Front Load Washer
Oe pops up and door is locked what do i do
OE is a drain motor error, or your drain hose is kinked, check to see if your hose is kinked on the back of the machine.
Once you check to see if the hose is kinked, press the power button on the unit, then hit "spin speed" and select it to "no spin", and then hit "play". This will manually set your unit to drain mode. If you still get this error, you will need to replace the drain motor on the unit.
Mar 30, 2010 | LG WM1814CW Front Load Washer
Lg front load washer WM2301 will not drain
drain hose may be bent or clogged, or the drain filter itself may be clogged
Sep 11, 2009 | LG WM1814CW Front Load Washer
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
Jul 06, 2009 | LG WM1814CW Front Load Washer
Error Message/OE
sounds like too much water is coming into machine.check water valve,and water sensor.it is bringing in too much water or not enough.
Mar 06, 2009 | LG WM1814CW Front Load Washer
I have an error message on my LG WM1814CW washer The message
This means the machine did not drain within a 10 minute time period. check the pump trap for debris and clean out. Check the drian hose. Check for drain pump operation diring drain period
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG wm1814cw washer
No, there is no access to the drain pump other than by removing the front panel to get to it.  It is a job that can be done but you will need to spend some time to disassemble the machine to get to it.
Sep 04, 2008 | LG WM1812C Front Load Washer
LG WM-2277HW Front Load Washer Logo
272 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
