Question about RCA E13320 13" TV
Issues w/ Sony DVD/VCR Combo
I purchased the Sony SLV-D380P DVD/VCR combo player (specs for player here). I hooked it up to my RCA E13320 TV (specs for TV here) via component connections on the back of the player and the front of the TV.
I tried locating the input channel on the TV (the manual for the TV indicated that the remote had an "Input" button, but on further examination, i noticed that the remote I had and the remote in the manual's picture were entirely different- a bit strange, if you ask me) but was unsuccessful. i found that when I unplugged the dipole antenna from the TV and did a "Channel Search", where it searches for an input signal automatically, it located a channel titled "VID" which did show the video, but which, when i plugged the antenna back in, i could not relocate, manually or otherwise.
What i would like to have is that the TV and the player work at the same time without me having to unplug anything. any assistance on the matter would be greatly appreciated.
2 Suggested Answers
  • 1694 Answers
SOURCE: RCA F32650 TV-Input 2 -Can I connect both Composite and Component video at same time?
I think you are right about VHS up front.......One more option =
buy a seperate video input switch box..then you wouldn't need
to use front input ........T.
Posted on Dec 19, 2007
  • 8197 Answers
SOURCE: rehooking an RCA 13 in.
To cahange the input you need to press the input button on the remote. You can get the manual on the link below.
Posted on Feb 22, 2011
0 characters
1 Points
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Standard (CRT) Televisions
We are unable to get video (picture) on our TV, when we hook up to our new DVD/VCR combo. The combo doesn't have an S-video port and our TV does. We get perfect sound though.
Your TV should also have a regular composite video input jack (yellow) in addition to the s-video input. Use that input instead of the s-video. The video won't be quite as clear as with s-video, but you have to work with what the combo gives you.
Apr 22, 2009 | Zenith C27A24T 27" TV
Hooking up DVD/VCR combo to directTV and console RCA
I'd first just hook up the DVD/VCR to the TV and get that working. I'm assuming all you need is the standard cable type connection. This will at least your 4 year old happy. Then you can experiment with the S cable. The S cable will give a cleaner signal from the DVD to the TV. then hook up audio and video cables from the Direct TV to the DVD input. The audio and video will be cleaner using S cables and audio and video cables, but stadard TV cable should get you going. You didn't mention what model DVD player you have. You may have to select the correct inout on the DVD for the Direct TV connection.
Nov 14, 2008 | RCA F32450 32" TV
Connecting dvd/vcr combo with tv and digital cable box.
You trying to put the DVD/VCR combo between the cable box and the TV? OK, cable out goes to vcr in, vcr out goes to tv, I think you got that. Now there should be a tv/vcr button on the vcr/dvd, you need to press that when the unit is on. Also, make sure you are on the correct input on both the vcr and the tv, usually video 1 or AUX and choose line in or L1 on the vcr/dvd. If the tv/vcr button is toggled, itll completely bypass the vcr/dvd player.
Mar 03, 2008 | Toshiba 32A41 32" TV
Hooking up a dvd/vcr player
The easiest way to connect the unit is via coax. You can come out of your satellite receiver via the "Out to TV" on the back of the receiver to the "In from Ant" on your DVD/VCR combo. You can then connect another coax from the "Out to TV" on the DVD/VCR combo to the "Ant/Cable" input on the back of you TV. Make sure the satellite receiver and the vcr are both modulated to the same channel, normally channel 3.
Dec 31, 2007 | Emerson EWF2004 20" TV
Connecting new dvd/vhs combo player recorder.
When you had the old combo hooked up the tv was on channel 3 now you have hooked up to s cable or component, you have to switch the tv input to the input you are pluged into using the tv remote
Dec 27, 2007 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Hooking up the PIP along with cable and a combo dvd/vcr recorder
From cable box,hook-up yellow,red and white to video input on TV ...Select that input, activate PIP...........Note:Split signal &
give 1/2 to cable box and 1/2 to Antenna A input on TV then hook RF out to tv to Antenna B................Let me know...T.
Dec 12, 2007 | RCA F35673MB 35" TV
Connecting VCR/DVD combo to TV
If that is the only input that the tv has it's still usable. Just plug the Cable TV or antenna cable into the DVD/VCR coaxial input labeled "in" (instead of the TV's) and hook one from the DVD/VCR's "out" to the "in" on the tv. Turn the TV to channel 3 or 4 (depends on DVD/VCR settings) and use the built in TV tuner on the DVD/VCR to change channels.
Sep 20, 2007 | Standard (CRT) Televisions
Hooking tv up to my vcr/dvd combo
hook the antenna to the VCR rf conecter IN. buy some RCA jacks and a three way deal and hook the red to sound red out ,white to sound output white, and yellow is always video hookit to yellow vido out on the vcr/dvd. The other ends go to the inputs on the TV....same color code. or you can just hook a cable to rf connector OUT on the vcr and other end to( it with problably just same antenna in) to TV.
Aug 29, 2007 | Sanyo DS31520 31" TV
Put the Tv on Channel 3
Jul 11, 2007 | Sanyo DS25390 TV
RCA E13320 13" TV Logo
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
