Tv won't start and red light flashing 6 times on the front
Hello, not sure what the problem is and what to do about it. I have checked the manual and nothing is mentioned about this . Do you have ideas ? I would so appreciate your help!!! thanks!!!
  • fishobass Feb 10, 2008
    Hi, i too have a 42" plasma philips hdtv. It is 8 months old and when turned off and sitting overnight began flashing red light 6 times. when this happens the tv will not turn on at all. If i unplug the tv for a couple of minutes it will start back up then the whole process starts all over again.. Anyone with any tips on the flashing light i am sure it's a code for a internal problem with one of the circuts.
  • city2000 Feb 24, 2008
    yes I bought a Bush TV from e-bay and set it up, started to watch it then after about 20min the picture disappeared and the red light on the top of the TV started flashing, now nothing works if you turn the tv on it just continues to flash with no sound or picture
The thermal fuse went out. it will have to be replaced. call Sony and they can get you the part and instructions, its cheaper than a repair.
Posted on Jul 07, 2008
Did you ever find a solution to that please let me know somebody asap email is bboycodak12@aol.com
Posted on Jun 24, 2008
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
50PF9631D won't turn on... red light flashing/blinking 6 times
Your TV main board is damaged and you need a new one. You can order one on ebay and fix it yourself. Make sure you have the TV model/serial number on the back label of the TV to have the right part when ordering.
Jan 09, 2013 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Philips 42PFL7603D/10 won't turn on flashes red 4 times slowly then red 6 times quickly
This is an indication of error codes for defects inside the TV. In order to ensure this is not caused by some erratic signal to system IC, switch off TV manually, Switch off power and remove plug and wait for 48 hours and retry. If it does not work even then, the TV might need service.
Aug 26, 2012 | Televison & Video
LG 17LX1R flashing red LED - TV won't power up
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | LG 17LX1R 17 in. HD-Ready LCD Television
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
I have a Sony KDF-60XS955 tv. It won't power on,
I have that manual. There are three lights to the left of the power button. One is labled LAMP. The manual states "The projection lamp, which illuminates the picture, has a limited life. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the LCD projector TV flashes, it is time to replace the lamp with a new one (not supplied). Use a Sony XL-2200 replacement lamp (not supplied) for replacement. Use of any other lamp may damage the LCD projection TV." I also found in a different page " LAMP LED lights up in red when the lamp for the light source has burnt out." I guess burnt out would be extream. I found one other if you had opened the light bulb cover and didn't close it properly. " If the lamp cover is not reattached securely, the self-diagnostic function may be triggered and the POWER/STANDBY indicator flashes three times." You can down the sony manual at http://www.docs.sony.com/release/KDF60XS955.pdf
Jun 02, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
I have a 32PFL5332D and when power turned on red light flashes 6 times then stops blinking for 3 seconds and starts again over and over. TV never powers up
Im afraid the set is probably in an over current protection mode wherebye it shuts down to protect itself as one aaea of the tv is drawing excess current, the pattern of flashes will have a code which would guide a techie to problem area, im afraid you will need an engineer visit,sorry George
Nov 03, 2010 | Philips 32PFL3403D/27 32 in. LCD TV
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
Oct 11, 2017 | Televison & Video
Tv turns off but will turn right back on
Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Televison & Video Logo
953 people viewed this question
Top Televison & Video Experts
