I'VE OWNED A SONY WEGA 27" FLAY SCREEN T.V.FOR A YEAR AND A HALF AND NOW FOR THE SECOND TIME THE THING WONT TURN ON. ALL ITS DOING WHEN I PUSH THE POWER BUTTON IS MAKING THE NOISE OF TURNING ON BUT NOT DOING IT. NO STATIC BUT THERE IS A RED LIGHT FLASHING 5 TIMES EVERY 5 SECONDS. I CAN'T FIND THE MANUAL IT CAME WITH BUT THE FIRST TIME IT HAPPENED I CALLED A NUMBER IN IT AND THEY CAME OUT AND TOOK IT AWAY AND BROUGHT IT BACK FIXED THE NEXT DAY. ITS A SONY WEGA TRINITRON SRSBBE 27" PLEASE HELP.:)
  • 8,617 Answers
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
Posted on Jan 16, 2008
I have a sony triniton model kv27fs100. Tv works great ...moved my room around and now when i plug in the WII to watch netflix my screen will go black but the sound stays on ...and getting the...
hi, code 5 in sony tv is indicates of a weak screen,which is too expensive to replace.
some times it helps to lower the brightness of the screen.by adjusting the button on
the flay back, the part that connect with wire to the top of the screen.good luck!
Feb 13, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
My TV turns on then off again when i push the
there might be any problem in the display or screen........check the settingd again and off the auto off and the timer functions.........or else there might be some internal defect which a mechanic can only repair
Oct 15, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Describe your Sony FD Trinitron WEGA This started
I have the exact same problem. If you get anywhere (I can't) please contact me at tbiasi@hotmail.com. If I figure it out, I'll get back to you.
Good Luck.
T
Sep 09, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony cybershot DSC-W170 lens malfunction
sounds like you have dust, sand of some type stuck in the retracting lense. Ive found someone to tell me to take out my batterys and SD card, then tap the bottom of the camera on a table top. Replace the batteries and power up. Doing this, I was told it loosens up the debri for the lense to retract to close and to open again.
Aug 24, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Top half black and bottom half OK on 27" Trinitron
could be an easy fix, soldering the pins on the vertical IC (IC501 I think)may fix it. also check the standup board pins being loose/dirty on the left rear (if yours has one). best quick test is bang on the set and see if the top half comes back for a second, if it does you have bad connections, an easy fix if you can solder.
thanks
E
Jul 18, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
SONY KV-XF21N90 WON'T TURN ON, Blinks 5 times
5 times flashing light shows following possible problems in your tv..
• G2 is improperly adjusted.
• CRT problem.
• Video OUT IC1800 is faulty.(C5 board)
• IC301 is faulty. (A board)
Most probably cause is G2 voltage adjustment. If you know how to do it, please go ahead or look a tv tech around.
Regards,
Sep 04, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony wega 27 inch
I posted originally about a year and a half ago about this very same problem. It is a known defect with the WEGAs that Sony refuses to do anything about. Here's the thread with my experience - the upshot is, try doing a "hard reboot" by unplugging it and leaving it unplugged overnight. That worked for me for about 18 months, but no longer...I'm replacing my 5 year old WEGA today (NOT with a Sony).
Jul 19, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
My tv dose not turn on
replace the flyback
available from for a great price from
www.electronix.com
May 22, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony tv timer light flashes wont turn on
Same exact thing happened to my 27" Trinitron purchased in 1998. I tried all the rudamentary stuff that Sony had on their esupport page, but nothing worked. In our case, it went out while my daughter was watching it. I think the time has come to scrap it, and consider a different television, and I don't think I'll go with Sony this time. I hope the rest of you have better luck.
Dec 05, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
235 people viewed this question
Top Televison & Video Experts
