my camera window displays "camera is unplugged pls connect your camera to the computer". I believed i have the driver & software properly installed. What proper procedure should i perform to make my camera work? I have an acer aspire 5600 with built in camera.
-   I HAVE A ACER ORBICAM BULIT IN THE COMPUTER IT WORKS BUT ON MSN ITS JUST IS BLACK AND FUZZY-   Guest
Oct 27, 2008
-   My camera were working ok and now suddenly it is telling me I must plug it into a USB slot. I have a Aspire 5670 with a built in camera.
-   WillemSL
Sep 01, 2008
-   Have a 5610Z built in, every time i try to open programme i am shown a message saying "obicam has stopped working will notify you when there is a solution.-   Guest
Jun 28, 2008
-   built in camera, first said it was in use by another application, tryed repairing the drivers, now says its unplugged
-   dinah93
Jun 20, 2008
-   acer orbi cam....it is sying camera is unplugged...The camera is built in to my acer aspire 5670 series latop......Any help would be great i have tryed everything i can think of.-   dagzsy
try to find the combinations of keys to activate built in camera... i
had the same issue on my laptop...and tried to find solutions like 2
weeks. :)... until i saw a picture of a camera on F7 key...:) ... i
tried key Fn+F7 and worked :). My camera works on all programs but in
Acer Orbicam Software says ''Camera is unplugged'' :) wtf ?
My acer orbicam is integrated into the screen of my laptop; Aspire 5610. When I try to open the camera it does so for only a bried moment, then closes. (The settings window stays open).
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install or Guides and Manuals if needing Orbicam instructions - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Jan 30, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Go to this thread, and read the very last post. It worked for me.
Hi Friends, Acer Aspire 5610-4648 PC Notebook main problem is Web Cam Problem, Windows XP Problem etc. For these problem you can visit a link by just Click Here . For any other problem with this Notebook you can Click Here
USE YOUR RECOVERY DISC THAT CAME WITH YOUR COMPUTER to reinstall all drivers and software needed back on your system this will include the drivers for your built in camera.
Before you install recovery disc make sure u back up any data and drivers you might need to keep such as printer drivers.
AFter reinstalling everything from yur recovery disc your camera should work fine if not your camera is bad .
my acer orbicam disconnects everytime I try to open it. What I really want to do is use my webcam with msn messanger but when I try to open the webcan using MSN it tells me that is being used by another application. Acer Orbican for aspire 5630. But acer orbicam is closed. I don't understand, before msn worked closing orbicam but not any longer.
