Question about Zyxel Prestige P-330W Wireless Router (P330W)
Xbox live via wireless
I was finally able to get into my router now i'm confused at what to do i don't want to take down my whole nat i just want to make my xbox 360 excempt from the nat firewall i called the xbox support line and they told me i need to open up ports udp 88, tcp 3074 and udp 3074 but what i would really like to do is put my xbox into the dmz.. p.s. some info that you probably didn't care to know about was that my xbox's ip is 192.168.10.35 and also on the test you can test on the xbox it says my nat is open instead of strict or moderate according to this i should be gaming with absolutely no problems but i still have them.
U have to go on the site mate 192.168.1.1 type that in and ur password should be 1234
then you go into Management then click on Bandwith MGMT
then click the advanced tab and click the lil xbox live box ;)
Posted on Mar 01, 2008
Hi there! i have bought a wireless zyxel router model NBG334W. I have followed the steps of how to install it on to my laptop , however, i am facing quite a few problem with it..the problem is that password that appears as default keeps coming back when i tried to change it , so i an not go further more..
thank you for your help in advance
Posted on Jan 27, 2008
3 Suggested Answers
SOURCE: Can't connect to XBOX Live because of Strict Nat settings Netgear router WGR614
I tried to find this "Access Point Mode" on the WBR 1310 as suggested above and I couldn't. I spent hours on the phone with support from Xbox, D link, and my ISP Bell Sympatico's technical support trying to get my Strict NAT to Open. I finally got everything working and if you follow the instructions below in order, you will too. Here's what you should know if you have the D Link WBR 1310 and Bell Sympatico Internet.
1. Log into the router and under the Setup tab click on "Setup Wizard" then on the next page click on "Launch Internet Connection Setup Wizard" In step 1 leave the password unchanged and click next. On step 2 select your timezone. On step 3 this is important, select PPPOE setting. On the 4th step leave the Address Mode in Dynamic and enter the Username and password supplied to you by Sympatico.
Once you have configured your Router to work with the PPPOE settings that Bell uses (Most DSL providers use this setting) you should now get a Moderate reading when you do the Network test in the Xbox dashboard.
2. Now go here http://www.portforward.com/networking/static-xp.htm and follow the instructions to setting up a static IP address on your computer.
3. After setting up a static IP address on your computer, go here http://www.portforward.com/english/routers/port_forwarding/Dlink/WBR-1310/Xbox_Live_360.htm and follow the instructions. Something you should keep in mind which isn't mensioned on this page is for each port you forward under the box that says "IP Address" do not put the IP address of your computer. You put in the new IP address of the Xbox 360 which was one of the 5 that was generated on the previous link. What you are doing is giving the Xbox 360 a new IP address and that new IP address needs to forward these port numbers to the Router.
4. Go into the Xbox dashboard and edit the Network settings. Under Basic Settings click on IP address and set it to manual. Now enter in the new IP address you chose for the Xbox 360. The subnet mask and the gateway is the same as your computer. (You can find these by clicking start, run, type in cmd then when the box comes up type in ipconfig/all
Under the DNS Settings it should be set to automatic and under Additional Settings leave them empty. Run the test in the dashboard and it should now be Open!
Also after reading several forums you don't need to enable DMZ host and leave the UPnP enabled. By default they are set this way anyway. Hope that helps.
Posted on Jan 05, 2008
  • 67 Answers
SOURCE: how do i open my ports?
Login to the routers web interface, go to the port forwarding page and insert the information required
Posted on Mar 31, 2009
Can't connect to xbox live
I don't know how your network is setup, but you may be able to find help here...
http://support.xbox.com/en-US/xbox-live/get-started/connecting
This page shows wired, and wireless connection, and also has a trouble shooting guide.
You may also have a strict NAT type that you may or may not have to adjust on your router. Here is a link to one of my previous posts about adjusting your NAT type, and Port Forwarding. Most routers are similar, but you will have to consult your manual or the makers website for specific instructions on how to log into your router.
http://www.fixya.com/support/t10868012-nat_type_strict_play_xbox
Dec 08, 2011 | Microsoft Video Game Consoles & Games
Switching from moderate NAT connection to an open NAT connection
yo tengo problema co el asistente de conexion del linksys
Feb 10, 2009 | Linksys WRT160N Wireless Router
How do i change my NAT connection from moderate to open
This one is simple. Find the IP address that your Xbox is assigned by your router, then put it into the DMZ. This also goes for PS3 users who are having trouble with internet access.
Change NAT to open
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
Feb 09, 2009 | Linksys WRT160N Wireless Router
I cannot connect to alot of my friends on xbox live and xbox live support says it has something to do with my NAT settings being on strict and i have no idea how to solve it.
Here are two pretty good articles about NAT and Xbox from Microsoft:
  1. http://support.microsoft.com/kb/908874/
  2. http://support.microsoft.com/kb/908880/it
What it comes down to, is that you have toopen some ports on your router and forward them to your Xbox. Go to http://portforward.com/, find the exact model of you router, (skip the stupid advertisement;-) and scroll down for your Xbox model. The descriptions are good and easy to follow.
In case you run into a problem with your Xbox, here is a link to Microsoft's troubleshooting guide: http://support.microsoft.com/kb/950314
Good luck and enjoy playing (hopefully soon)!
Dec 01, 2008 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
How to fix nat on xbox live
type "msconfig" in run
then startup then disable all.
then aply ok
then restrt .
thats it.
Nov 15, 2008 | Zyxel P660HW-D1 Router
Xbox 360 to wireless laptop
Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
Mar 16, 2008 | Microsoft Xbox 360 Console
Strict NAT
Ok this is how its done. Open your DMZ on your router interface click enable. The IP address you'll have to enter the last digit. This IP address digit is found on your xbox, look under your xbox network setting an get the last digit of IP address an this will only set your xbox to open. bang thats how u fix it. Very simple. any Q's am @ murdock_theory@yahoo.com
Nov 30, 2007 | Belkin (F5D8231-4) Wireless Router...
Nat / strict
First, why are you connecting to your laptop? Second, reset your modem and router. I doubt you need to open ports that are not normally open...but if you think you need to do more, access the router and open the ports manually.
Nov 27, 2007 | Microsoft Xbox 360 Console
Zyxel Prestige P-330W Wireless Router (P330W) Logo
170 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
